I am selling this Phasor with a rare purple metallic colour (only 2 were made in this colour).
It has been fixed up from a previous owner on ES with brand new battery and updated tuning to pull 6KW. This thing flies, topping out at around 80kph!
This bike is a dream to ride. With economical riding it will get 100KM range. Go hard and you'll still reach 60km!
I have tuned the torque curves to make it pull about as hard as possible without flipping off the back. The suspension is tuned to float over almost any obstacle, and the whole bike is setup ready to go for it's new owner with all electrical work done securely and all components triple checked and serviced for longevity.
Electrical:
Asking price is $3350AUD. Payment in person (cash) or bank transfer only.
I will consider shipping it within Australia (at buyers expense), but only for someone who is willing to talk with me on the phone so as to avoid scammers.
PM me if you are interested.
Cheers
Electrical:
- Mxus 3k motor with 8ml of fresh ferro fluid for cooling
- Upgraded phase wires to 8AWG fine stranded silicone for minimal heat generation
- ZL Motor 70A sine-wave controller (peaks to 80A+) - completely silent!
- Cycle Analyst V3 (v15 F/W - Tuned for 6KW)
- GPS speedometer (not pictured)
- 20S8P - 72V 28AH BRAND NEW battery
- Uses Sanyo NCR18650GA cells
- 100A capable bluetooth smart BMS
- Handlebar mounted temp display
- 60-100km range!
- Half twist throttle
- Regen enabled with button on left hand side
- Fast 5.5A charger for a full recharge in around 4.5 hours
- Schlumpf 2spd high speed planetary gears (good for pedalling at over 70kph)
- DNM 200mm forks
- Rock Shox long travel rear suspension
- Magura front brakes, Shimano rear both 203mm rotors
- Rear 19" MC rim
- Front 24" radially laced fat rim
- Shinko 241 trial rear tire
- Berm Master front tire
- Specialized pedals
- Heavy duty stand
- Large comfy seat
- Riser bar for displays
- Front wind deflector (also hides the wiring)
Cheers
