I fancy getting a balance charger and now that I'm spending a fair bit of time in my motorhome it makes more sense - as it can replace a load of clutter, including things like my ebike charger.
However, what I've just been wondering is; if I get a decently powerful one (ie 1000w+, though for the moment shouldn't need more than 250-500w), will it do a good job replicating a 'smart charger' designed for lead acid.
I've looked at various solutions to charge the leisure batteries in the motorhome.
If it will, would it be possible to run it from the alternator to charge the lead acid batteries?
Would I be able to run it directly from solar panels, to initially get around buying a solar charger, if I got some solar panels.
To power it from the generator, for the moment I would use a Draper 30a 24v car battery charger, which I believe should be ok.
Money is a bit limited at the moment so trying to figure the best 'bang for the buck'.
The leisure batteries run at 24v as does the vehicle. I have a Honda EX4000 generator. The alternator is 'unkown' rating; I would ideally like to get a decently powerful one (ie 140a with a good proportion of that at idle for a sterling) and consider getting rid of the generator, adding a big inverter which could then have some extra batteries to play with.
(Yes, I know it's not your typical question around here, but I reckon this forum's got the best chance of having people that know... incidentally, I would love to make the motorhome a hybrid with a massive battery pack to also use for daily stuff, but that's rather a long way off
