Not sure what you want to achieve. Perhaps dont disconnect the display as without it you can not receive any visual feedback from the system. error messages icons appearing/disappearing etc, all useful info in fault finding..
The motor is probably continuing to spin after its cut off because without any electricity running through its coils the resistance to spinning is drastically reduced so it spins with the momentum its already built up?? That is if i have understood the scenario correctly (40% confidence?)
all the back n forth with your other post is work
- so its a gokart your building and you dont want 2x displays on view ?
(future tip, lay out your goals clearly in post #1)
These battery wires connecting to the display complicate matters, without them there is a chance of running headless with throttle control by shorting pins 1, and 2 form the controller (a hack to make the press of the P button), But i dont think that will fly here..
Afaik generally there are 2 lil computers involved in the control system one in the controller working out the phase stuff depending on speed control input etc, the second in the display, and these 'talk' to each other with the controller passing info to the display for display such as power usage, speed etc and the display captures your input when selecting features and passes that back to the controller sort of thing.. Now your system seems to have 3 x computers involved as its also introduced communication ?via the display? to the battery bms.
So to remove the display you will need to trick the controller that its got a display attached to send speed etc to and to accept the user input turning on the bike..
AND fool the battery bms its connected to the display of a 'valid' machine.
While the controller may be 'tricked' easily enough, no one has cracked battery codes en-mass perhaps the odd one has been cracked?? Im not aware of any so this is a show stopper unless you build the displays into the kart to maintain the comms , Or buy new batteries or refit a generic replacement bms to each battery??
