neilr1967 said:
What specifically about the specs of the Headways from EV components make them more powerful than say a Ping 48V 10ah or 15ah? Is it the "Built in BMS with max continuous discharge of 60a Max cutoff discharge current 100A" .
-Neil
The diffrence is the C rating. A ping battery can handle 2C, or a discharge of 2 times it's capacity in amp hours. Meaning a 48V 10AH Ping battery with a C rating of 2C can supply 20 amps continously.
The Headway cells I believe have a C of 3C. The BMS rating is diffrent. it has nothing to do with the cells themselves and its the rating of the cells that matters.
The best practice when picking a battery is to chose one that matches or exceeds the controller. If your controller has a max of 35 maps, then a 10AH battery with a 3C rating would be too small.
