Planning on building two or three 48V batteries to get extended range on Bafang BBS02b, and I stumbled upon LG M48 and LG M50L as great options, costing around 1.60e for M48 and 2.1euro for M50L from nkon.
I know the M50L has been tested on the forum and performs well. The datasheet also lists 1000+ cycles that corresponds with the testing. I couldn't find a datasheet for M48, and if their labeling is consistent with how M50 is inferior to M50L in number of cycles and degradation, I'm hesitant to pull the trigger M48. M48F datasheet snippets I've seen look fine enough, but it's probably different model.
Additionally, my XTAR VC4SL is testing the dozen M50L I already bought from nkon at around 4600-4700 at IR of 50-80mOhm. Not great, not awful. Of course the measurements from the charger should be taken with a grain of salt since its a cheap charger.
What would you guys do, pay the extra 25% for M50L or "gamble" a bit with the M48? I'll probably buy 130-150 cells to build two 1KWh packs and do ride -10C temps as well, so also need to be mindful of how much current gets drawn since LG lists 0.5C discharge rate for 10C to -20C.
