Bikes that are Compatible with a BBSHD
JayCee said:
Don't believe you, unless you shimmed the bottom bracket on the drive side or had an older unit that was cast differently. The current drive unit does NOT fit onto a 68mm BB. When the motor plate is bolted to the motor, the space between the plate and the drive-side housing is 73mm. It CANNOT be installed without after-market shims.
I used two primary lock rings. So what's the beef? EVERY kit on EVERY build has some niggling detail. This anal retentive preoccupation with easily overcome details is contrary to kit building.
Lurkin said:
Tomjaz, would it be possible to enquire with Luna on this distinction? Is it actually possible to get a BBSHD for 68mm BB width from them? (yes, any answers will go updating the wiki)
The answer is no. The BBSHD requires aftermarket BB shims to be installed onto a 68mm BB, and there is no 68mm kit available, at least not in the US. The other option is to cut down the motor plate mounting area on the motor, but that seems sketchy to me. The required 5mm shim wants to be installed on the plate side, which creates rotational issues due to loss of the plate's biting teeth into the BB, which does have to be resolved - I like my drill n' pin idea for that issue - easy and reversible.
Niggling details IS an issue on a kit like this. We're not talking about figuring out how to run wires or where to put the battery - the drive unit simply doesn't fit. Marketing a kit as being suitable for something, then finding that it is geometrically uninstallable with the supplied materials is unacceptable. If the kit was supplied with the required shims, or came with an extra lock ring for use on a 68mm BB, then that would be fine. Either that or DON'T market it as suitable for a 68mm bracket without explaining what needs to be added.
That being said, once I received the motor and figured out what the problem was, Luna did allegedly send me out a shim kit, although I'm still waiting for it so my project has been on hold for a week so far. I don't have a good bike shop nearby to try and find esoteric hardware like many of you city-folk do.
You DON'T NEED TO SHIM UNDER the fixing plate. There is NO issue except the one you are making up and it's unfounded, without merit, and that of an inexperienced builder with less sense, than cents, apparently. So you sit, with no riding, when what's really lacking is common sense. Thousands of us road our 01's and 02's with a single lockring. The fixing plate fits against the BB and the spacer on top of that. You COULD be riding instead of niggling about details you remain clueless about. You can lead lead a horse to water...
Hi all,
i found THE ARTICLE that answered 99% of my questions. If i had found this article before, I would not have made the mistake of buying my Giant Anthem 2015 27.5.
https://www.empoweredcycles.com/blogs/news/101474694-bottom-bracket-standards
Step by step what to check before buying a bike for BBSXX.
Jerome
Good shop too!
I fail to see where locking the bbshd to a sleeve in a press fit BB is better than locking it to BB spacers. In both cases you're relying on a smooth face to transmit torque. I reckon it's likely to work fine in either case, as long as everything is properly tightened.
Thank you.
Chalo raises a good point here, but a press fit sleeve could be far tighter (or even glued in addition) than some ring spacers held by a BBSHD nut. But, either could work or fail. BBSxx users do need to keep vigilance on the motor's tightness to avoid problems in the future.
Actually, you're just a hack that would build something dangerous and prone to failure. BBS01s and BBS02s DO work on 68s, BBSHDs do not, so you're arguing in a vacuum. No, you can't just have a 5mm misalignment on the motor mounting plate. No, you can't just bend the 'tabs'. You're being ignorant as well as obstinate.
From the article posted above:
"Many people are unaware of this fact, but yes you can get a 73mm if you wish, but the flip-side is the 73 mm only fits 73 mm shells <emhasis added>, making the 68 mm more versatile to swap to another bike someday, just a little food for thought."
At any rate, my spacers finally arrived. As the drawing on the Bafang site indicated, the 73mm kit IS perfectly centered (as per cranks) on a 68mm frame when the drive side is against the BB, so a 5mm spacer under the mounting plate (non-drive side) is the correct solution for centered cranks. Unfortunately, with this setup, the Luna Eclipse chain ring (with more offset than stock) only had a fraction of a mm clearance to the chain stay. I figured it would likely end up rubbing due to frame flex, so opted to spit the difference and put two half-spacers on either side, yielding only a 2.5mm crank/frame offset which I doubt I'd notice. That also gave fairly close to an optimal chain line.
I also used the epoxy-blob trick to reduce pressure on the down tube from drive torque.
The mounting plate is knurled to dig in to the side of the bottom bracket, so its not a smooth surface with installed as designed. The spacers defeat that feature.
I am trying to figure out why you spaced over the whole drive instead of just the chainring when the whole point of ordering the spacers was to have centered cranks? Couldn't you gotten the needed clearance by hot gluing a washer or three between the chainwheel and the drive at each bolt as a shim and then keeping the centered pedals?
My point is that the knurling digs into the ends of a BB30 adapter sleeve, but the adapter itself is still a smooth fit to the frame. Sure, there's some pressure and friction at the fit, but no direct way to tighten it. Alternately, the lockring jams spacers to the frame as you tighten it. So you can lube the threads and tighten the bejeebers out of the lockring and thereby have some control over the holding force.
So notch a spacer? This solves the rotation issue, but not drive offset.
Chalo the mount is serrated/knurled. It bites into the BB when tightened hard enough. Its not as strong as if it was threaded on, but its certainly been tight enough if decent force is applied. Again, if spacers could be supplied with notching/serration/knurl to match the mount, it would solve this issue and allow the motor offset to remain in line with the frame BB offset. [EDIT] Yeah, just talking to myself here, apologies re read what you wrote. :oops:
Either way, I kinda doubt Bafang will do this. Better off using it with the incorrect matched offset in the short run, buy time to work out a custom spacer solution in the long run.
The whole point of ordering the spacers was to be able to mount the drive unit, not to center the cranks. You CANNOT mount a BBSHD "68-73mm" drive unit onto a 68mm bottom bracket without aftermarket spacers. Spacing completely under the mounting plate centers the cranks, as the 73mm kit is designed for a 68mm spacing (even though it can't be mounted on one, ironically), however that creates a potential mechanical problem, as the mounting plate is pressed into a shim and not the BB. Spacing completely on the drive side eliminates the mechanical problem, but creates a 10mm crank offset relative to the chain stays. Since I didn't want a 10mm crank offset I had to live with the potential mechanical problem of shimming under the mounting plate anyway, so I choose to split the difference on the drive unit (2.5mm on each side), eliminate the need for a chain ring spacer, and suck up the 5mm offset.
Glad to see you got it close to where your happy Jaycee. It is always a bunch of little compromises that get you. Being boxed in with the offset chainring and chainstay clearance gives little choice on where you can place it. Easiest thing for bafang to change to accommodate this specific issue is to lower the mounting bosses for the support bracket and include some small shim washers. Personally, I would like to see a strap style support for the motor and not rely on the little nibs on the bracket to prevent rotation. It all seems a bit light duty to me given how many are using the kits.
I believe that there is a 68mm-specific kit, at least Bafang advertises separate kits on their site. If so, it would have lower mounting bosses on the motor housing, with the entire rest of the assembly identical to the 73mm kit. I suspect that the US sources simply bought all 73mm kits, assuming they would be compatible with the thinner 68mm brackets, when ironically, the exact opposite is true. The 68mm kit (if my motor boss depth assumption is correct) would not only go onto the 68mm bracket unmolested, but would also fit onto a 73mm bracket with 5mm spacers on the motor housing bosses (just as was done with the old BSS02).
An external motor support would be nice - the good news is that the drive torque pushes the motor into place, but I could see it starting to bash around if it gets a little loose.
Hi!
You can add on the list Rocky Mountain Element 50, 2006.
BB width: 73mm
BB inside diameter: 33.7mm
Jerome
p.s. just ordered Bafang BBSHD from Luna cycles, yes yes yes!!!
Hi Guys,
So I ended up getting a 2010 Giant Anthem X4 and the BBSHD fits like a glove.
Keep the suggestions coming
BenTMS
Add the bikesdirect fat bike Motobecane Boris the Evil Brut Sprung to the list.
Here is a link to a build article:
https://www.empoweredcycles.com/blogs/news/109966534-motobecane-boris-the-evil-brut-sprung-bafang-bbshd-build
