Doctorbass
I'm experimenting on the last gen CAN BUS BIONX controller and discovered that they use 75V mosfet ( usually used for the 42V automotive industry.
Someone gaved me a 250W "deffective" motor that had the controller completly blown a year ago.. (I also started a thread about testing it with 300w external controller for fun...to be continued :wink:
Then I bought from ebay two new gen controller ( the one i'm studiing now)
Guess what.. i'm in contact with the main engineer that is responsible for these controller at EPS ( Bionx) !!
he admited me that they had a leak at their Toronto factory and someone got 50 of these controller... the one that have put them on ebay probably....
The guy at Bionx is nice and give me some info form now ( he did his thesis on the bionx motor and controller and not is working for EPS
After a close look on my controller here is what i discovered:
ALL their motor controller use the The mosfet model IRF1407
http://www.irf.com/product-info/datasheets/data/irf1407.pdf
VDSS = 75V
RDS(on) = 0.0078Ω
ID = 130A
The 250W use 6 mosfet and the 500W use 12 mosfet.. I still dont know if the 350W use 6 or 9.. but i would guess 6 is ok due to the low RDS on
-Also each output phase have their own shunt!..
-They are 1.5mohm smt
-The 250W have 2 in parallel
-The 500W have 4 in parallel
the 350W probably have 3 in parallel
Each phase have 3 parallel 100uF high grade capacitor ( still unknown V value)
The heart of this controller is a PIC30F6015 of 80 pins from Microchip.
A High-Performance, 16-Bit Digital Signal Controllers
-144 Kbytes on-chip Flash program space
-up to 40MHz
Motor Control PWM Module Features:
• 8 PWM output channels:
- Complementary or Independent Output modes
- Edge and Center-Aligned modes
• 4 duty cycle generators
• Dedicated time base
• Programmable output polarity
• Dead-Time control for Complementary mode
• Manual output control
• Trigger for A/D conversions
http://elektronik-lavpris.dk/files/sup2/70150C[1].pdf
More to come.
here are some pics ... as usuall :wink:
Doc
VDSS = 75V
RDS(on) = 0.0078Ω
ID = 130A
-up to 40MHz
More to come.
Doc
