MadRhino said:
Hi Doc
This thread died after dismantling and observations. I wonder if you have made any attempt to run a bionx motor at higher voltage, either by modifying the actual bionx controller, or using an external controller.
I've been running mine (350 watt 36 volt Bionx system) at 64 volts with a $25 sensor-less controller at the 1500 to 1600 watt level for over a year. I'll try to make a very long story short...
I blew the first 350 watt motor in the first month I had it. I was going down hill in excess of 42 MPH when all of a sudden the rear wheel LOCKED!!! Needless to say I left rubber on the road and was lucky I was not hurt. Fortunately this happened on my trike. Had I been on a two wheel bike I don't think this would have turned out well as all. I don't even want to think about what could have happened had this motor been mounted in the front fork of a two wheel bicycle when this happened!!!
People around here have been known to go down the side of the same mountain on a road bike doing 65+ MPH so 43 MPH is no big deal around here especially on a trike.
Normally i repair everything myself but since this was under warranty, back to the facotory it went for replacement under warranty.
A couple months later same thing happened. Different hill but approx. the same speed. Somewhere around 42 to 43 MPH. Back to factory. Replaced under warranty. Starting to see the pattern?
The same thing happened a THIRD time but this time the system was out of warranty and it was my baby so I had nothing to loose by opening the motor. I even posted a video on how I did it.
http://www.youtube.com/watch?v=Uy6ua2XoorM
I used nothing special but as others have pointed out you do have to be careful and tap the other side of the motor housing otherwise you may crack it. The Bionx motor is a bit of a pain as there is no way to get at the internal controller without taking all the spokes out and completely tearing the motor apart. Not a design that lends itself to tinkering or modifications!!!
I replaced the MOSFETs. Everything was fine for another six months or so. Then I did it again. Only this time when the wheel locked up smoke came out of the battery pack. At this point I had it with Bionx. I had thought about removing the controller from inside the motor and mounting it OUTSIDE the motor but it was obvious that this system has a design flaw and I was tired of dealing with it.
I opened the motor (hopefully for the LAST TIME!!!), gutted it of all Bionx electronics, brought out wires hooked to the three phase wires, hall sensors, and torque sensor.
Although I have run this motor with the hall sensors hooked up, it runs so well without them hooked up that I no longer bother using them. I have converted three Bionx motors so far. All of them are using either one of these two controllers:
http://www.endless-sphere.com/forums/viewtopic.php?f=4&t=13691
Same controller but later version:
http://www.endless-sphere.com/forums/viewtopic.php?f=4&t=20176
I chose this controller because it was cheap, had regen braking and allowed the option of not having to hook up the hall sensors. This could be an issue if the motor has a bad hall sensor and you don't want to have to deal with replacing it.
Although this is spec'd as a 500 watt 12 MOSFET controller, I've been pumping over 1500 watts into the 350 watt Bionx motor for over a year now with no issue whatsoever!!! (25 amps x 60 volts = 1500 watts and 25 amps x 64 volts = 1600 watts the highest I've dared push this controller so far.) Top speed at 60 volts is close to 40 MPH using a 20x1.75 (46x406) knobby BMX tire. I've pushed this controller to 64 volts hot off the charger but since the internal capacitors are rated at 63 volts there is some risk in doing this. Best to keep it at 60 volts or so if you want to play it safe.
The controller comes from the factory with the internal current limit is set to around 25 amps or so and seems to do what it's supposed to do as far as limiting current is concerned. Since I have more than enough power at this current level I made no attempt to run it any higher. I always peddle when I'm on the bike. The motor is more of an assist for climbing hills with a heavy load but I do occasionally open it up on the open road just for fun and to give my legs a break. I've been known to haul more than a 100 pounds of groceries home at times!!!
I plan on changing the capacitors to 100 volt units so I feel a little more comfortable when the battery is at 64.0 volts hot off the charger. There is no problem running the Bionx motor at this voltage. It shows very little heat running at the 1500 watt level. However, after changing the capacitors the next issue is going to be the MOSFETs in the controller I'm using as they are rated at 75 volts and I already know more than I care to know about the voltage rating of MOSFETs and what can happen when blasting down a hill at high speed!
One other issue to keep in mind when pushing the voltage limit of a controller that has regen braking. If you are right at the voltage limit (in this case 63.0 volts) and you hit the electric brake, your voltage may go UP another volt or so, depending on how stiff your batteries are. So be careful about using regen braking in the first couple of miles until your battery voltage drops to whatever you consider safe. Having a MOSFET go dead short is not only a nuisance, it can be extremely dangerous when the rear wheel locks up. As mentioned before, I don't even want to think about this happening to a front hub motor on a two wheel bike!!!!
I have no idea of what this motor can be pushed to. I live in the foothills of the Allegheny Mountains (3100 foot peaks) so it gets a workout climbing hills but it also gets a workout blasting down those same hills while using regen braking. I used to have to change disc brake pads several times per year. Since going to regen braking I've had the same pads on the bike for over a year now and for me that's 5000+ miles. I've been gas free for the past six years so I depend on this system to get to where ever I have to go...
