RRF test Correction
I have a 408/4011 C-lyte hubmotor with 36-72v 20 amp controller that has a 3-way switch: 4011-off-408.
On the RRF test on 6th street hill I errored by having the control switched to 408 on the RRF run (30.3) and by having the control switched to 4011 on the "nake" run (24.6). This gave an incorrect result which to Knoxie just didn't smell right. Kudo's to Knoxie for giving it the Trademark "Knoxie's Smell Test". I apologize to Knoxie&all for not re-checking sooner. (Note to self: if someone smells shit, it might be time to check your shoes.) A rookie mistake not knowing there would be different amounts of drag from the same motor. So I stand corrected. The RRF speed increase is about 8%. The TD1F increases this to the 15%+ range.
Comparable roll tests I've done on Court St. hill shows the resistance of the hubmotor:
Switch to 4011 24.6 mph max
Switch to "Off" 27.8 mph max
So there can be a real drag from the hub motor on the 4011 setting at 20 mph +/-, on the 408 setting I imagine the same thing happens, just at a proportionately higher speeds(35 mph +/-). By turning the switch to "OFF" the drag largely goes away.
Again, My apologizies to Knoxie for not giving his comments more credence. It's good to have some one double check one's work.
The point is still valid: a Fairing can save considerable Watts.
But my forum etiquette was sub-par.
The numbers from 2nd round of fairing test.
The TD1 Fairing.
Starting at the SE corner of 10th & Court Streets with a small push off to get rolling, I rolled down to 4th with no pedaling, usually sitting up right. Wearing the same clothing and bike trim. The controller switched to "off". Using a Garmon GPS for speed. No Wind.
The Run down Court St. provides 4 gradually steeper sections follow by a flattening 5th section allowing for slowing before the 4-way stop sign.
It is a good course as it has allowed me to see the differences between the various fairing configurations at increasing "power" levels(slopes). And still have time to come to a safe stop.
Type
Regular Nake Bike (Bike) top speed 27.8 mid-way speed (mph) 20.5
(Bike) w/ mid-frame cover (Bike2) top speed (mph) 28.9 mid-way speed (mph) 21.6
(Bike2) w/ TD1 fairing top speed (mph)31.5 mid-way speed (mph) 22.5
(Bike2) w/ TD1 fairing w/ "ConeAss" top speed (mph)31.5
(Bike2) w/ TD1 fairing & tuck top speed (mph)32.3
(Bike2) w/ TD1 fairing & seat
lowered 4" and tuck top speed (mph)32.7
modified w/ interior enclosed
seating upright top speed (mph)32.3 mid-way speed (mph) 26.5
(Bike2) w/ TD1 fairing modified
on 4th St. Hill rolling start top speed (mph)34.1
I took one run with the RRF on the Court Street course and it was in the middle of the speeds, as I remember it. (Sorry, it's back to work for ol' RRF.)
I have taken the TD1F on 4-5 long trips though some strong gusty winds (10-20+ mph) and was glad to have it. Didn't get blown around too much, it was better on the downwind leg than the "RRF". Glided away from some road bikers on a downhill going 20mph+.
On the other hand at 13-14 mph, I'm just a bit slower.
Looking at the numbers, one could guess that it's working well in the 20's mph, by 30mph or so the air flow is starting to fail. Haven't tried strings yet to see what is going on.
The speed increase are 4% for just the mid-frame cover and 16% with the TD1F, with even higher increases in the mid 20's mph.
These gains seem modest until you discover the amount of watts they represent.("Your mileage may vary.")
I've been using the "trunk-space" in the TD1F for holding the on-board charging equipment, a lock, maybe a small pack, half-eaten burrito.....
Love having on-board charging, it rewarms the burrito.
Later
Kyle
