I'll try to keep it short! I want to DIY a 230v Gasoline Generator with pure sine output, to power my air-heat-inverter-pump thing, which peaks at 2500W@230v. I have a bunch of junk at home and I'm not afraid to get my hands dirty, I have and know how to use a welder, cabling sizes and proper connections, oscilloscope, Arduino etc. I work in server/compute/datacenter tech and have built electric gocarts and etc.
Where I live, we are expecting power cuts to be more common, and we have no heating other than electric. Modern urban house etc.
The Daikin heat exchanger/inverter is brand new state of the art, and I'd hate to risk it using anything but a controlled full Sine-wave inverter. So I was thinking that a Server UPS would be sweet. Doesn't get more professional that than, in terms of the inverter.
Countless people on Youtube have built very nice lawmower-powered-car-generator-generators with an expensive Inverter attached to them. Fine, but such an inverter is way out of budget for this project, since I hope and expect that I'll never have to use it. It's a fun project that I can actually justify to my wife, she likes the idea of having power.
So I thought I'd get a huge but cheap UPS and hook up to my bank of 12v batteries, and charge from the motor which drives tha Volvo Generator... great. Until I realized that the UPS's that size have their batteries in serial, runnung 72 or 192 volts... Hm. So I need to charge/run them at 72 volts while the UPS is also consuming the same power, using the batteries as a buffer if I momentarily exceed what the mowerengine/generator can generate.
I have at my disposal:
* 5.5 HP lawnmower engine that runs great, but the rest of the mower expired.
* 12 x 12v, 12 Ah AGM UPS batteries from a previous project.
* 12 (14.5?) volt car generator, 140Amp, from a Volvo S80.
* A compressor that leaks air, but with a good 240v single phase motor (2500Watt?) (I'm in Europe). Can that motor be used as a genny? I don't think so?)
* A 24-72 volt 3000Watt Brushless E-bike type motor, new in box. Also from abandoned project. Can that be used with some sort of controller/rectifier? That would be awesome since it's 72 volt.
Can get for no och few money:
* APC UPS, 6000XL (6000 VA) one-phase with bad batteries. It takes 16 x 5Ah in 192v batterypack, and the current one is dead..
* Eaton 3000 UPS (~2800W peak), which I believe has 72 volt packs. This would be the best with my current battery stock.
Crazy but feasible ideas welcome. TIA!
Magnus, Sweden
Magnus, Sweden
