smithinparis
- Joined
- Sep 17, 2008
- Messages
- 59
I will first start off by stating that I am completely to blame for my procrastination of providing more protection of my controller. I've been planning on sealing it off for sometime, but given that I always watch the weather, and don't bike in the rain, (60 km round trip in the rain as a commute to work is something I've tried to avoid).
Anyway, on to the problem ...
Yesterday it was calling for sun, but I ended up getting some patches of wet flurries on my way to work. We aren't talking about a storm by any stretch of the imagination ... my jacket and pants got wet, but I was in no way soaked. I got on my bike at the end of the day to head home, and managed to get about 100 meters, when the low battery light came on. Thinking that was odd, I switch battery packs, and managed to get a little further when the low battery light started to flicker and I felt a rumbling in the wheel and then it went dead (power light is off too). Unfortunately, I was in the left hand turning lane (front of the pack none the less) of a busy intersection when it went dead, and trying to peddle that bike across the intersection was like hauling a ton of bricks. So I got across the intersection and unplugged the motor from the controller (which loading the motor), and rode home.
So at home, I took the controller apart and the insides were completely soaked (dripping wet), and to make things worse, it was really dirty because of the trail that I ride on (which kicks up lot of dust). I haven't yet seen any obvious areas where it has discharged and let the magical smoke out that makes things work, but I did see some questionable connectors. I cleaned the assembly with rubbing alcohol, and dried it up, but I haven't tested it out yet to see if it's ok - I'll do that tonight.
So now for my rant ... this controller is for a *bike* and bikes are ridden outdoors where they are at the mercy of the environment. Nobody would accept it if the bearings on a bike would seize because of a little rain, or your speedometer would fail because it got damp, or if brakes stopped working completely. A little give and take is expected though, eg clean your chain occasionally, don't store your bike wet for long periods of time, don't expect anything electronic to survive a huricane, and expect the brakes to not work at 100% in the rain - but at least the manufacturers make an attempt at making sure their products are protected to some degree.
Why are controllers *any* different? Why is it ok to leave gaping holes and entirely unsealed gaps so that dust and debrie can get in completely unrestricted, along with a little bit of water, in areas that contain sensitive electronics which are mixed with extremely high currents? The manufacturers of the Crystalyte controller made absolutely no attempt at offering any real protection other than a porous case.
Anyway, let this note be a warning to anyone out there like me ... don't expect any protection from the elements. Make sure you shelter the electronics somehow. Seal it with silicon, put it in battery bag or case - just keep it safe.
Does anyone have any advice to offer? What do you do to protect your electronics? Does anybody keep in in a bike bag? If so, what about heat sinking, does it become a problem?
