cruiserbikeman
- Joined
- Jan 2, 2012
- Messages
- 82
I receive this battery Monday. Charged it up. Connected it to the ampedbike controller and tested the throttle and worked like a charm! Took it out for a ride Tuesday and everything was fine. Today I decided to work on switching over to the Lyen controller. I had changed the power leads and phase wires over to anderson connectors. The ampedbike wires already has andersons on the phase wire. I only had the phase wires connected, nothing else. Connected yellow to yellow, green to blue, blue to green. Then I connected the battery wires from the Ping Battery to the Lyen controller battery wires. There was a huge spark. I disconnected within 2 seconds. The pictures show the results of what happened:
I thought the battery was toast!
However, I reconnected it to the ampedbike controller and it still works. I then hooked it up to the charger to see if the BMS would function The BMS still works and the battery still charges. The bike runs at turbo speed. No smoke or anything after taking a ride for 5 miles. It looks like the problem was not the wire but where the lead on the battery connects to the negative wire. It's not broke or anything but seems like excessive current or voltage heated up things melting the tape and plastic shrink wrap. Oh ,by the way, I checked the voltage on the 60 volt Ping Battery with a multimeter. It was at 72 volts off the charger. I did this 6 times. Just to make sure this wasn't a mistake, I checked the voltage on the 48 volt Ping Battery and it was 55 volts. I guess I'll see what happens in the coming weeks.
