controller and Throttle like in the VECTRIX
guy w.
Hi all!
1. I'm looking for a controller and Throttle like in the VECTRIX‏- https://www.google.co.il/search?q=Throt ... MygAjBM%3A
for goldenmotor 10KW Fan Cooling- Model: HPM-10KW - BLDC Motor
http://www.goldenmotor.com/
http://www.evalbum.com/preview.php?vid=3048
2. Is there a way to a step up from 48V to 120V?
Since I have no more room for additional more batteries on the motorcycle.
Best regards,
guy w.
1. This is the VECTRIX‏ Throttle-
viewtopic.php?f=3&t=39983
I wanna stop the bike by the motor and use the brakes only for Emergency.
Who can produce controller and Throttle like this for Brushless DC motor?
2. This is one way to do a step up from 48vdc to 120vdc-
http://www.aimscorp.net/12000-Watt-Inve ... 40vac.html
and put phase rectifier bridge to Change it to dc.
but it too heavy (Almost 80kg) and cost 3049$.
There must be another way to do it, I don't need the sine Wave, so it also can be a lot weightless.
Great appreciation,
Guy w.
Why the links I've posted not open correctly?
12000 Watt Inverter Charger - 48 volt 120/240vac-
http://www.aimscorp.net/12000-Watt-Inverter-Charger-48-volt-120-240vac.html
vectrix throttle-
http://endless-sphere.com/forums/viewtopic.php?f=3&t=39983
