Tommy L
Hillhater said:Tommy L said:I want to go DARKSIDE and build a build with an In-Frame Motor.
Do you go direct from motor to big rear sprocket/belt pulley?
Or do you use reduction?
Or does it all depend on the rear wheel diameter?
Or all of the above?
" direct from motor to big rear sprocket/belt pulley" ......is using reduction ! ( single stage)
and how much reduction is needed will depend on the wheel diameter, motor RPM, speed required, etc etc.
But i suspect you were asking if you needed multiple reduction stages ?..which depends again on what rpm range your motor will run in.
Right you are! and thank you! (wow I can't believe I missed the "Single Stage" part)
I'd like to do a Scratch Build. I've recently got my TIG welding ticket
is the ticket, and No Gear Box.
My last build (I've built 5 so far) is a FS Mountain bike with 9C2810 and I run either Grin C7225 at 76.8v nom A123 or Lyen 4115 at 128v nom A123.
I tired of having the battery pack on my Back in a Backpack. Also, If I'm running the Lyen with 128v, my speed can be 50mph/80kph and that gets scary
on a bicycle. 30mph/50kph is plenty which the Grin C7225 @ 76.8v nom gives me.
So now it's time to move the Lyen 4115 over to another build. 17" motorcycle rims, Pirelli Dot, Moto front triple tree suspension.
Getting the rims and tires purchased and delivered first so I can figure the circumference of the wheel.
The hardest part about this whole build is: Why reinvent the wheel? I have a Moto License, so why not just get a donor moto. 250 Enduro? 650 enduro?
Also, I have a 1985 Honda VT1100C that still runs and is plated. I've thought of just pulling the engine out and making her electric (I still have my 2003 Honda VTX 1800C) Or selling the 1985 for some cash to do a scratch build, but the 1985 has shaft drive (reduction built in) put an ACxx Motor and some cells and done. Doing any of the Moto conversions means Licensing and Insurance. Scratch Bicycle means so Licensing/insurance.
Also, I have a late 90's Sears Mountain Bike with no Suspension. Big Triangle for battery, so I could mod it as a Longtail and put rear suspension and a Triple tree up front, switch the wheels out for the moto rims and pirelli tires.
Man oh man, too many choice!
Tommy L sends......
I've moved this over to: http://endless-sphere.com/forums/viewtopic.php?f=28&t=50275
