huntercook
- Joined
- Feb 18, 2008
- Messages
- 3
Hi everybody. I've been lurking for quite a while, but this is my first post, so go easy...
I have a couple of related questions regarding the DeWalt 36v gear that now seems to be all the rage in ebikedom. The first one seems less complicated, but the second may be cooler.
First, it seems to me that a DeWalt DC900 drill is an ebike kit in disguise. It's supposed to be 750W at 33v, and variable speed with the controller in the battery. Is there any reason this motor/battery/controller would not work (or work well) for this application? It seems to me that one could simply cut the drill up into 3 pieces (battery holder, handle/trigger, and motor/housing/fan), mount the pieces, wire them together, get a rear wheel with a second freewheel on the other side, chuck a sprocket into the drill, chain it up and ride off. I'm only wary of this because it seems too easy and too cheap...you can get a battery, charger, and drill on ebay for about $200 total, and 36v ebike kits are over $400 near as I can tell. So if it's this easy why isn't everybody doing it?
The other question centers on the DC9360 battery pack and its internal speed controller. Could these batteries be used to run a normal ebike motor without a controller? Seems one could save a bit of money that way, particularly if they could be used this way in series to run a 72v motor. I'd love to have a 2s3p setup running a crystalite if that would really work...seems like by skipping the controller you end up with LiFePO4 weight/performance at a lot closer to SLA prices. Of course, I haven't the first inkling of an idea as to how to wire such a thing up. Any gurus out there want to give me a whack with the cluestick?
Thanks
Hunter
p.s. Doesn't it seem strange that the DC900KT drill kit (drill/battery/charger) runs $450 on ebay while you can get the parts separately for under half that?
Thanks
Hunter
