RebelRider.Mike
Hi folks,
I'm planning an eBike and thought I'd share my progress here. I guess I'll start with some specifics.
Me:
I'm around 230lbs. Could stand to lose around 40. I'd like to ride my bike more, but the hills are killer for me. And they seem to be everywhere. I'm looking to add a motor to help get up the hills. I don't want the bike to do all the work. I need the exercise. But I could really use some assistance.
The Bike:
I have a Raleigh of some kind that I received as a gift a while back, and I've recently put my own seat and handlebar on it. A friend of mine installed new cables that he made to custom length to fit the new bars. He even found me some new brake pads.
The bike weighs about 36lbs. There's an ill fitting rack on the back which I will be replacing. It has 26" wheels and ordinary brakes that clamp down on the rims.
The Battery:
As the title suggests, I will be building a battery from reclaimed laptop cells. It will have a range of 42-58.8V. 51V nominal. I'm hoping to keep the current draw to 9.5A. This should allow a power range between 400-500 Watts, and I think it will be able to operate at that output for 3-4 hours. I'm not sure though. I haven't actually built it yet.
The E-kit:
I'm still researching this, so I'm not sure what I'll be using. I do have some characteristics in mind though.
The wheel should spin freely when there is no power to it.
I want to monitor the battery Volts and Amps directly. I can rig something up if I need to.
I'd like the system to be able to operate on the voltage that the battery can provide (42-58.8V)
I need to be able to limit the current draw from the battery to 9.5A so as not to overtax the cells.
I'd like the motor to have enough torque to assist me up hills. I don't need speed. Just a bit of extra power.
To help distribute weight, I'm thinking of using a front hub motor.
I suppose I'll need to be looking for a motor, controller, throttle, and some kind of display. The Golden Motors Smart Pie caught my attention, but I think it is going to be outside my price range. Also, I don't think that one would spin freely when I don't need it.
Its the geared motors that spin freely without power right? Or have I got it backwards?
Also, I'm seeing 72V controllers out there, but not 72V motors. Are these controllers limiting voltage to the motors?
Well, I've got more research to do. I'll post more as I make progress.
Me:
The Bike:
The Battery:
The E-kit:
