forcefed86
- Joined
- Jul 31, 2022
- Messages
- 73
Goal is to get a 7 sec 1/8th mile and sub 4 second 0-60 times. 40-50kw or so should do it. Total weight assembled is 123lbs. I'm 220 and 6'4.
Best time to date on Draggy is a 4.2 0-60 and 8.1 @ 79mph in the 1/8th. 5.3x 330' time.
That was on 111v SOC and 375a. Plan to turn it up to 450a and fully charge to 117v and make some changes once the weather is nicer.
Started with FB market place purchase of $100 on this new in box 24V Hyper Mini scooter.
Purchased $80 shipped steel 490mm swing arm off Aliexpress.
10" QS212 5k motor and a ND96850 Fardriver controller.
Stripped motor electronics and rear wheel. Frame weighs in at 24lbs.
Split the swing arm down the middle so it was wide enough for the motor. 208mm dropout width. Mounted the wheel and welded the center back up.
Mocked it up and welded swingarm solid to the frame. Adding bracing as necessary.
Mounted and wired in controller, throttle, boost button, regen, and routed brake lines. Test Fit battery pack. 28S 15AH LIPO.
Slapped it all abck together.
