i run marathons and they work well
i have thousands of miles
chalo is right though Mr Tuffys do cause flats. i experienced this. i added the liners for extra insurance, since the hub motors are heavy , i ride fast, and riding a cargo rig i simply cannot break down , it has to be bullet proof...
the first flat i had was fortunately overnight when the bike was parked. the chaffing between the tire liners and and inner tube ruptured the inner tube... anyway i had a few thousand miles on that wheel, i just replaced the inner tube and if this happens again ill ditch the tuffy... i also now put my tire psi up high, since that incident im probably upto a thousand miles so far so good
edit: Tue Dec 08, 2015 8:58 pm.
week ago my rear tire went..woke up in the morning to find rear tire flat. again there was a small hole where the mr tuffy crossed. there was also a small wrinkle in the mr tuffy as well, but i ignored that. the tire served well. i have replaced the inner tube and put the mr tuffy back. the one thing i love about mr tuffy is even if the inner tube gets a hole, its so stuck to the inner tube that it keeps it plugged till i get home as i usually only realize the tire is flat next morning. i dont think ill take the mr tuffy off even if it causes rubbing, as i have too much weight on my cargo rig and i need it. when i inspected the mr tuffy i found alot of dents in it , probably caused by going over debris , rocks and crap on the side of the road.
new edit: feb 7, 16
edit: Sat Jul 02, 2016
no flat yet but getting close to 8k
http://www.bikeforums.net/general-cycling-discussion/354517-do-mr-tuffies-wear-out-tires.html
my rear tire developed a small bulge and the tire has a hop to it
upon inspection it was close to the area where the tuffy's overlap.....not good
i think its time to dump the tuffy's - strange the front tire has the tuffy's and didnt develop this problem. perhaps the liner wasn't sitting right or shifted somehow.. not sure... still regardless the tire developed a bulge.
edit Jul 04, 2016
on 2nd i took the inner tube out and put a dollar bill on the inside of tire where there was a chaffing
today on my ride home was 40 meter away.. got real lucky my real tire got flat
so the tuffy went back in.... i went thousands of km,s without this problem
i guess my rig is just too heavy to live without them
edit: jul 7
my rear tire blew up- the bulge ripped
i was 10 miles away from home ended up getting picked up
jjul25
new marathon tire on rear with no tuffy- so far so good
front tire has tuffy and no issues still
i believe that rear has all the weight, and the tuffy chaffing inside the tire ruined it.. so i now carry a patch kit and go tuffy free
