Risposta di deepseek(IA):
That's right, if your bike's motor and control unit are protected by a **15A** fuse, it means that the system is designed to work with a maximum current of 15A. To avoid exceeding this value, you can install a **current limiter** or a **current controller** that prevents the battery from delivering more than 15A.
### What to look for on AliExpress:
On AliExpress, you can look for a **DC current limiter** or a **current controller** with the following specifications:
- **Input voltage**: compatible with 36V (make sure it supports at least 36V, but ideally a wider range, for example 20V-50V).
- **Maximum output current**: adjustable or fixed at **15A**.
- **Power**: make sure the device can handle the required power. For 36V and 15A, the power is \( P = V \times I = 36 \times 15 = 540W \). Look for a limiter that supports at least **600W** to have a safety margin.
### Examples of products on AliExpress:
1. **DC-DC Converter with Current Limitation**:
- Search for "DC-DC buck converter current limiter" or "DC-DC step-down converter with current limit".
- Example: a module like the **XL4015** or **XL4016** (adjustable up to 5A) or the **LM2596** (up to 3A). However, these do not support 15A, so you should look for more powerful models.
2. **DC Motor Current Controller**:
- Search for "DC motor speed controller" or "PWM DC controller".
- Example: a 36V and 15A PWM controller, like the **KY-009** or similar models. Make sure it is adjustable and allows you to set a current limit.
3. **Specific Current Limiters**:
- Search for "current limiter module 15A" or "DC current limiter 36V".
- Example: modules like the **DROK DC-DC Current Limiter** (available on AliExpress) that support voltages up to 36V and currents up to 20A, with manual adjustment of the current limit.
### AliExpress search link:
You can use these keywords to find the right product:
- ["36V 15A current limiter"](https://www.aliexpress.com)
- ["DC motor current controller 36V"](https://www.aliexpress.com)
- ["PWM DC controller 36V 15A"](https://www.aliexpress.com)
### Tips:
- **Check reviews**: Make sure the product has good reviews and is reliable.
- **Check the specifications**: Read the technical specifications carefully to make sure that the device supports 36V and 15A.
- **Safety margin**: Choose a device that supports a slightly higher current (for example 20A) to ensure greater durability and safety.
Is correct?
I will buy the correct limiter, can you suggest of is necessary?
Thanks
