sketchism
Established
you shouldn't need to pad it at all they should pull tight around your hub
do you have a photo?
sn0wchyld said:hey sketch, is this you on ebay, or at least one of your resellers?
https://www.ebay.com.au/usr/customcarbide?_trksid=p2047675.l2559
just rather give my money to the actual creator rather than some copycat.
also would be interested in a 'shorter' version of the hubsinks with shorter fins. understandably would reduce the effectiveness but would be good to have an option for a more subtle look.
ridethelightning said:just thought id post this for anyone who is super dedicated to keping their hub cool![]()
FWIW, unless you use an antioxidizing compound (some type of heatsink compound, for instance) on those surfaces, they're going to reoxidize fairly quickly. (also, the surfaces are almost never completely flat to each other, so the airgaps between them won't conduct heat nearly as well as the heatsink compounds will--even the basic plain old titanium oxide white paste is better than air.ridethelightning said:i then did the same thing to the undersides of the hubsinks, removing the aluminium oxide anodising, till i had mirror aluminium surface.
SlowCo said:ridethelightning said:just thought id post this for anyone who is super dedicated to keping their hub cool![]()
Is there ferrofluid in your hub motor?
I used white or grey heat sink compound in a syringe.amberwolf said:FWIW, unless you use an antioxidizing compound (some type of heatsink compound, for instance) on those surfaces, they're going to reoxidize fairly quickly. (also, the surfaces are almost never completely flat to each other, so the airgaps between them won't conduct heat nearly as well as the heatsink compounds will--even the basic plain old titanium oxide white paste is better than air.ridethelightning said:i then did the same thing to the undersides of the hubsinks, removing the aluminium oxide anodising, till i had mirror aluminium surface.).
i carefully buffed the paint of my qs 205 before adding the hubsinks.
the sinks have worked a treat! i love watching the temps dropping by the second when i ease off the throttle or stop. before i installed them, it was like 30 times slower to cool off.
https://endless-sphere.com/forums/viewtopic.php?f=2&t=48753&start=1302hias9 said:Did anyone compare cooling performance of dual row hubsinks to single row hubsinks on motors like mxus 3k and qs205?
It would be nice to know if there is a significant boost in cooling performance.
hias9 said:
hias9 said:Is it better to grind off the black coating from the motor where the hubsinks will sit or does it not make a difference?
rockstar195 said:Has anybody have luck running the hub sinks ONLY, with NO FF or Statorade?
