Experimenting with infrared 250 watt lamps- 25-35F cold front, heaters maxed out.
That is quite a feat considering humans can't see IR light. :ROFLMAO:
Yes, I am able to see red light, as I said in my post. Try it! Your complaint might be with GE for calling it an IR lamp, when in fact it confuses you because you like to twist everything. Not only can I see the red light, I can feel it penetrate. The warmth I feel is said to contain wavelengths both visible and not visible to the human eye.
Go find the TV remote. Is it under the blanket? Press buttons on remote. See nothing. Now get your smart phone. Use camera to look at TV remote. Press buttons. See light with camera that is invisible to see with your eyes?
Why can camera see invisible things?
Because a camera's sensor can "see" frequencies a human eye can't? :unsure:
Same way a radio works. It listens to frequencies a human ear can't hear then converts them to frequencies a human ear can hear.
Well... not quite.
Sound is vibrations in matter - for us typically air, although it's common to hear sounds under water as well. These are physical vibrations of the matter - it shakes back and forth, or compresses and relaxes. Ears respond to the physical movement of air, water, other gases or liquids or even solids - you can put your ear against a railroad track and hear the sound of an approaching train - because the metal rail is physically moving, vibrating. Sound is carried by vibrating matter. The vibrating matter causes a physical part of your ear to vibrate as well, and nerves notice this. That's how we hear.
No movement of matter, no sound.
Radio is vibrations carried as electro-magnetic waves. Yes, it's vibrations. It's vibrations in the electro-magnetic wave. It is not vibrations in any matter. Yes, radio waves can pass through some matter, but the matter is not vibrating - electro-magnetic waves are vibrating. I know of no reported instance of an ear noticing electro-magnetic waves. Ears don't respond to radio waves at all - it is not a matter of the difference in the wave frequencies.
Electro-magnetic waves do not cause a vibration in a physical part of your ear, and ears thus do not report any sound from exposure to electro-magnetic waves. Such as radio. Ears do not hear radio waves.
Radio waves are not vibrations in matter. No matter is involved, no matter is vibrating, and ears don't notice anything. Radio waves carry signals, information, but they do not carry sound itself. The signal can be used to create movement of matter, and that is sound, but the sound itself was not carried somehow on a radio wave - just some information about the sound.
Just as very minimal equipment can pick up and de-modulate AM radio - corrosion on a coin and a safety pin can be adequate, if not satisfying - so there are reports of people picking up AM radio from the dissimilar metals in their tooth fillings - this is still not 'hearing' radio waves as what they are hearing is the wave modulation applied to the radio carrier wave being expressed in some other medium (read that over until you realize that the sound information is distinct from the underlying radio wave that transports it).
I don't know further if the sound the person hears through their fillings is due to actual mechanical vibration in their mouth (probably) that corresponds to the audio modulation or if it is in fact an electrical transmission of the audio modulation which is picked up by nerves. That latter would be interesting, but it's still not hearing radio.
But ears do not respond to radio waves, unless the radio waves are microwaves that cook the ears in question.
That's basically the case for most RDAs. it's the minimum of what you need to live on. They also give the red light to artificial vitamins that have a 0-5% absorption rate.
I take 4000 IUs in winter.
In Coconut oil...
There's plenty of sunlight in winter here, but most of your skin is covered in thick clothing.
Ye vitamins are a whole different story; They're Crap!
The cheapest nastiest everything.
Often with no bioavailabilty.
Synthetics.
obscure eg: B3
The amidated forms; Nicotinamide etc; are the END product of cellular energy production and a negative regulator of that energy production.
I get into it here a bit.
And here.
Once you know your story and take optimal forms at optimal dosages they stop being crap and start being F-ing expensive! :)
A lot of vitamins are crap.
B vitamins don't work for me at all. This may be a 'me' problem. I have to buy a specialty B complex from europe that are more bio-available than usual, otherwise i fall into deep depression.
UVA+UVB will raise your vitamin D levels, in minutes. Oral vitamin D may raise it in a month. That's why i love my lizard lamp. No more seasonal affective disorder for me.
Vitamin A from retinol is close to useless due to it's very low absorption rate.
Approximately 50% of a multivitamin is useless because the vitamins are in a cheap format with poor bioavailability. Those ones may have thousands of the RDA value.
If you do not educate yourself on how the human body works and how to best take care of it, you're basically toast because most people in suits who have acronyms before their names in the USA cannot be trusted. The default state is to be miseducated.
Past 3 days 25-35F morning lows very cold for FL, coldest in 15 years.
Heaters are maxed out giving me a warm spot in any room with about 1000w. They are shut off when I leave the room, except I keep 650w 24/7 in the BR. Kitchen is 55F away from the heaters.
Hope you are warm too :bigthumb:
Using about 20 kwh/day, neighbor is about 85 kwh/day with a heat pump!
