Hi. Anyone got Fardriver controller with 14: MOSFET Lowside error? Trying to diagnose for a friend. He has two ND961800's with same error! Has anyone repaired one? Aluminium power mamagement PCB with DPAK MOSFETS. No shorts from phase 1,2,3 to + or -. No burnt components. Fun. Would one open circuit phase winding in motor cause this? No obvious shorts on motor. Maybe motor hall sensors wired wrong? Any info most appreciated. Also - has anyone replaced any of the DPAK MOSFETS on the power board? Looks like a lot of heat needed to desolder / resolder. Thanks in advance. Cheers.
