Edit: Here are some specs and stuff
-It weighs 47 lbs! So I added about 21 lbs overall. Not too bad, right?
-The most I've hit so far is 5kw peak. Amazingly the tiny motor survived
-I went for a ride of about 3 miles doing around 25 mph and pulled about 2 AH, so the range is about 6 miles on 44v 5ah @ 25mph. I can't wait to get another 5ah and start riding it to school. Some more waterproofing needs to happen before that, such as fenders and a mudguard for the motor
Also, I need to figure out this stupid thing where the power occasionally randomly cuts out. I can't tell what's making it happen. It seems like it cuts out more at a certain speed, and above or below that speed, it doesn't. It always cuts out for half a second or so and resumes accelerating immediately. Hopefully if I set the ESC to log the voltage ripple and throttle input the next ride at 5 hz, I should get some answers.
I promise I'll stop bumping my own thread now
-more.
If you are wondering what the white tubing is, that's the battery enclosure. It's metal gutter pipe. I chose it just because it's easy to cut to length, it was in my garage, and it fits the batteries well
. One end is plugged with a piece of wood and silicone sealant. I bent a piece of plexiglas that fit over the other end and had a little hole for the wires, and I was going to seal it, but I went through a bumpy vacant lot and my knee knocked on one of the edges, breaking it in half
The cover for the electronics that are in the hard drive enclosure is another bent piece of plexiglas. As you can see, I lit that one on fire when I was bending it. I'm better at bending plexiglas now, however
And I rigged up a parallel harness for my 150w turnigy charger so I can parallel balance and charge both packs simultaneously, and eventually, all 4 or six packs 8)
I had almost kept my build tape-free (electrical tape was used) and then I discovered this cool, thick, really sticky, and transparent tape that I think would do a good job of sealing the electronics enclosure. Oh well, it's not too visible from far away.
There's another day's worth of updates.
