kmxtornado
So we know what we're dealing with:
More photos on Instagram @ricecooler and also in the photo thread here: http://www.endless-sphere.com/forums/viewtopic.php?f=12&t=70650
Actually, it's just the amp hours rating of battery that I need a recommendation on. 10ah vs 15ah for my application.
I bought a Cruzin Cooler and for those that don't know what it is, it's basically an ice chest with a motor. I use it as my stroller with my daughter. Benefit of being able to ride and store gear (diapers, milk, clothes, etc) in the cooler compartment. IG @ricecooler if your'e interested. Lots of fun until the controller and possibly other components fried yesterday. Time for new components if the manufacturer doesn't cover any replacements under warranty. This might be my opportunity in disguise to upgrade
PRIORITIES:
Goal is to bump up the speed through overvolting but to do it safely. Torque for slopes is more the priority though. I'm okay replacing motors every now and then. They aren't that pricy and the swap is fairly easy. I just don't want to be replacing controllers and reconnecting those wires all that often. Getting stranded that one time wasn't an experience I'm looking forward to again.
A. Maintain descent range
B. Torque for slopes. Not hills, just minor inclines of uneven ground. This thing stock is weak. It can barely go up a driveway.
CURRENT SETUP:
24v 18ah from two 12v 18ah Lead Acid batteries that currently fit into a nice clean battery box to power a 500w motor. Tops out at 13mph.
NEW SETUP:
This is where I am looking for expert advice from you folks. I gave up on the idea of reusing my 36v 10ah (I think) LiFePo battery from my previous projects. I figure I'd want to run both ebike or escooter and this new cooler at the same time to ride with friends. Also the battery has been rebuilt since it was bulging and I don't really want to put too much stress on it. I'll just stick with the cheap lead acid batteries for the cooler.
I'll of course be getting a new 36v controller to handle the new voltage going into the system and throttle too. There is a company out there that specializes in modifying these with an overvolting kit (excluding the required extra battery). I don't doubt the claim of reaching speeds of 23mph or at least 20mph, but wondering what batteries to get as far as amperage is concerned.
QUESTIONS:
1. I'd like to keep the same physical volume of the batteries so that it fits in the battery box nicely. Necessary b/c it's heavy and hauling that in and out of the trunk separately from the cooler itself is much easier on my back. This limits me to 12v 15ah batteries tops. 12v 10ah batteries are also a consideration. 12v 20ah batteries of course exist, but 3 of them for a 36v setup wouldn't fit in my stock battery box which is a requirement for me. Do I go with 12v 15ah batteries or 12v 10ah batteries? 10ah I understand will have less range, but perhaps also less stress on an overvolted system and therefore less likelihood of burning anything out, correct? Does amperage affect torque I would need for slopes? When I'm stalking slopes, I'm talking minor change or grade, but of course any improvement would be awesome. I'm not expecting to build some amazing monster out of nothing but if i could take on San Francisco hills that would be a dream come true.
2. How much range am I sacrificing generally by going from 24v 18ah battery pack to 36v 10ah battery pack with all else being the same and the extra weight of a third battery being negligible for simplicity? I go to street fairs and car shows on this thing and would like it to last 4-6 hours going 3-5mph 95% of the time but have the capability of showing off a bit at 20mph in 5 second spurts.
3. The wires connecting the controller to my motor melted big time. Should I be worried about a dead motor or is it just the controller that needs replacement?
THANKS IN ADVANCE TO ALL THOSE THAT REPLY. I really appreciate your help greatly. Hoping to get my daughter and me back on the road again to take more photos for you guys. I'm no expert in electronics but am eager to learn.
PRIORITIES:
CURRENT SETUP:
NEW SETUP:
QUESTIONS:
