I own two Kukirin scooters (newer 10×2.75 versions) and I need the opposite of the usual request: I want the 25 km/h limit to be permanent and non-defeatable, so they legally qualify as speed-limited vehicles. Police here know the brake-lever + double-click-power toggle, so because the limit can be removed, they don't accept the scooters as limited.
What I've already established:
The brake + double-click-power toggle works and the state persists across power cycles, but it's reversible — that's the problem.
G2 (48V): controller marked "G300", firmware JBWCK6P-V1.1 / software RND4825-V1.17. No unused/limiter wire on the controller.
G2 Master (52V): dual controllers, board partly labelled "AT2-K-1-PCB", SN LZHB202505KZ2932X. Controllers are potted deep in the deck, can't see the silkscreen. No unused wires on either controller.
Consumer settings menu (triple-press power) on the Master is reduced: it shows P01, P05, P06, P08 only — P02, P03, P04 and P07 are absent. So there's no menu-level global speed limit (P07) and no wheel/voltage params exposed.
The dealer confirmed they have a method to lock it permanently (they charge €99/unit) but won't disclose it, and explicitly said it's not a firmware update — they called it a "secret."
My questions:
Is there a service/engineering menu behind a non-standard entry (button combo or code) that exposes a hard max-speed parameter on this firmware? Exact entry sequence?
If it's a hardware/harness change instead — which existing connector/pins, and what signal (jumper / resistor value) forces a permanent cap that the toggle can't override?
On the dual-controller Master, is the lock a single display-level setting, or does it have to be done per controller?
Goal is genuine compliance — a fixed 25 km/h that survives any button combination. Any verified procedure for these exact controllers appreciated. Thanks!
My questions:
