Goaskalice
I want to find the easiest way to modify/bypass top speed limiter on my gyrocopters Zeno 2.0 E scooter. It is 36 V and I think 500w. I tried to locate the speed limiter wire to cut it, but I cannot locate and also had intended to try to do a shunt mod, but the controller is completely filled with epoxy coating the entire circuit board, and I cannot seem to identify any shunts on the circuit board, is there a way this can be done perhaps on the display or are one of the wires in the harness the speed limiter? If none of the above can be done, what will be my best option two replace the controller and or motor hub or what somebody please give me some answer or suggestions on what to do preferably in an affordable way I’ll attach photos of the controller and what I am working with
