hillslayer@
Regular
The display let's you go up to 28 mph , after changing the wheels front fork and handle bars and adding hydraulic brakes bike feels pretty stable at 30 mph plus. As they came from Walmart 20 mph was not confident inspiring.
Nope, the charger color is red, saying it's charging. But even after an hour or more the BMS doesn't seems to have turned back on, so I'm going with something bad has happened, probably BMS, but I dunno. So it's on them to replace it for me, before I crack it open and see if I can figure out what's wrong and rebuild it to make it usable.The 0v means the BMS has turned off. If the charger stays at it's "finished" state instead of starting charge (whatever indication it uses for this), then it has turned off both input and output, so that the charger can't put current into the cells and charge them, because of a problem of some kind inside the pack.
Could be bad cells, connection fault, itnerconnects, blown fuse, or even a failed BMS, in order of general likelihood.
In this case, it was a combination of BMS disconnected/user error. I thought the button was just "what's the current power capacity look like", not "turn on/off". And then combined with BMS being disconnected, it needed to be connected to the charger for the button to actually work to turn on/off power to the BMS, which then detected the charging voltage, and reconnected and working just fine now.When a battery acts "wierd", I prefer to open them up and verify all cell voltages, connections, etc., because sometimes it's just a wierd design, but someitmes it's miswired (if the wierdness happens from the beginning) or it's a cell fault (or bms with stuck balancer draining cells that causes a cell fault), and in either case I'd rather know about it...but if it's a cell fault you might not see the issue after charging it, until it sits unused long enough to self-drain again.
Yup, skimming the manual I missed that the button is actually on/off somehow.The instructions are very clear to charge the battery for 4 hours before initial use. You found the little battery button, which needs to be pushed for a few seconds for the battery to turn on. I guess you know all of that now.
I bought 3 of them and have had no problem with the electric part of the bike on any of them. The manufacture date of my 3 is 11/21, so the batteries are 4 plus years old.
