The glider I want to power is a 15m , (49.2-ft ) span Atos VRX that gets a (19 : 1 ) L/D
and I believe the newest E-Paramotor SP140 V2.5 , will be perfect for my project !
That system runs on 24s ,and uses the FOC type ESC ; it's suppose to be more efficient
at lower throttle settings. Even if the ESC has a break on it ; I will still place a disk break
from a motorcycle to stop the front mounted folding prop from windmilling.
I have foot launched Hang gliders since 1977 , and Paragliders since 1989 ; but launching
off a mountain with a 15m glider on 2 fake legs is really difficult in turbulence.
The Question :
I am Fine with handling a 12s LIPO , (or ION) as the voltage does not scare me , and I
use them a lot in my T-Rex 800 Heli ; 24s is a different story , and yes I am scared !
I will be building my own packs from the newest EVE 21700 50PL ; they bin tested to
180a , and can take 125a continuous.
If I build 2 packs, in a 12s , 3p configuration and connect each pack to one side of the
ESC , with a big honking insulated manual switch between them to complete the circuit for the
100v series ; would that be a good or Dumb idea ? I will not build a 24s battery pack ; and
don't even want to charge or carry one around.
Only other problem will be figuring out the prop pitch speed ; but a fixed ground adjustable
prop will solve that one , and I can get a folding one that size later.
Bille
The Question :
High density solid state drone battery cell
The stable growth path from semi-solid to all-solid state battery enables a dual technology platform 17Ah 300wh/kg 3C-5C 22Ah 290wh/kg 3C-5C 24Ah 300wh/kg 3C-5C 29Ah 300wh/kg 3C-5C 31Ah 320wh/kg 3C-5C 32Ah 300wh/kg 3C-5C 35Ah 320wh/kg 5C-10C 38Ah 370wh/kg 5C-10C 11Ah 480wh/kg 3C-5C 12Ah...
arosenpower.com
Bille
