Hello ES, I haven't posted here much because I'm trying to build something first, then talk about it later... in case I end up not being able to finish for whatever reason. However, I need to ask about this because it's somewhat specific.
So... along those lines of not being able to finish something for various reasons... I started my project almost two years ago and many things have happened to put it on the back-burner, mostly health related. Unfortunately I thought it a good idea at the time to jump on a lot of new A123 26650M1 cells for a reasonable price, so I did. I bought 74 3S packs from migueralliart, which totals 222 cells, with the plan of breaking the packs apart and building a 216 cell pack with them and to have 6 extras for testing and/or backups. Each of these 3S packs came installed with a BMS board (you can probably see where this is headed). When they got here I checked out each pack and they almost all had a nice consistent voltage of 9.5x.
So long story less long, they got shelved before I had a chance to break most of them up which didn't concern me because I've read very good things about their shelf life. Well, I completely forgot about the BMS' ability to suck them dry even though I KNOW better. Stupid, stupid, stupid. They were draining for 1 year and 9 months.
Fast forward to the near-present, I dug them out of hibernation because I was reading something unrelated that made me remember and realize what I had done. I went through them all... and have been kicking myself in the ass ever since. :x :x :x
The BMS boards are now all gone so they're individual cells again. Actually, 24 of them have been since the beginning because I broke those apart at the time to mock something up. Those 24 are all resting right around 3.2V, all fat dumb and happy. The other 198 though...
Strangely, they're all over the place... mostly not a good place. There was no consistency between cells even in the same positions of each pack, so I don't know what the deal was with those BMS boards.
Rather than posting each individual voltage here, I'll group them.
3.00+V............x4 (not worried about these)
2.80V-2.99V......x55
2.50V-2.79V......x59
2.25V-2.49V......x29
2.00V-2.24V......x29
1.50V-1.99V......x19
1.00V-1.49V......x3 (lowest being 1.09V)
Obviously some of these should be okay, obviously some others should be paperweights. My question is... What is the best way to go about seeing how many are salvageable and what their reduced capacity and discharge capability is and seeing how many are entirely gone? I did slow charge one of them from 2.10V to 3.45V, it didn't get warm and it's resting now at 3.32V. That's a good sign I think, but of course it means little as to its usefulness and I haven't tested further than that.
I've been looking at some of the larger RC chargers that do IR measurements among others, but I'm wondering if it's even worth bothering with it because these won't be made into a pack now, and that makes the endeavor almost pointless. I'm just super bummed about it. I can think of a couple uses for a few here and there, though, so maybe all is not lost. If nothing else, I'm really curious to see the data, but I really don't have time to play around if it's not worth it.
It's not a quick process to go through 198 cells any way you go about it, but is there a way that makes it reasonably doable? I'm willing to spend a decent amount on a good RC charger and a PS because I can still use it in the future, but I'm not sure what the best one would be for this situation.
As you can tell, I'm endlessly toiling over the situation, so I'd like your thoughts.
On the bright side, battery technology is always improving and even now there are some very impressive 18650 cells out that have higher capacity, higher voltage, weigh a lot less, and are of course smaller, and are equally as robust and safe as the A123 cells. I won't make the same mistake again though, I'll wait to buy into it until I'm much closer to using it.
Even if you have no input for me, I appreciate you reading about my $1332 epic FAIL.
Maybe someone can learn from it.
