How do you keep it on the road? Are you cruising at 70 mph.
I typically cruise around 30 mph using under 1 kW plus pedaling. I only do stupid things when no one is looking. I have gone 70 mph a few times using the 3T motor without the body shell on the trike running a 20S6P pack of Molicel P42A, and it needed all 10 kW to cruise and only for about 2 miles at a time. With a body on it, I suspect its top speed increase will be significant and it might see its power requirements drop to 1/3 at speed. With field weakening, 100+ mph may even be possible with a single motor with an aerodynamic shell on it. Acceleration is faster than most cars.
That said, it is currently not on the road as I have it taken apart for upgrades. I'm waiting on more parts to arrive because the 4th gen KMX spindles in my possession do not fit the 2nd gen and 3rd gen frames I have, so I'm having a piece of the front suspension that was made to fit my front hub motors and 4th gen spindle instead made to fit my 3rd gen spindles that do fit. I will have to take the suspension apart and install the new piece.
The 2nd KMX frame I might use to build another tadpole to make use of this 3T motor, while I convert my current one into a quad. I will eventually have a body shell on both vehicles, plus the Milan running a 2kW 26" Grin All-Axle setup(I still have to widen the rear wheel well of that one due to a rubbing issue). I think I'll set the tadpole trike up like an open-wheel open-cockpit race car for summer riding with the design tailored to allowing me lots of airflow, the quad will be an enclosed streamliner with a digital HUD projecting speed on the windscreen for riding in rain and inclement weather and will be my comfy "GT car", and I might build one more e-bike maybe a delta trike or another quad to use as a low-speed "pickup truck". The Milan is eventually going to be my ultimate "long-range" build due to its efficiency, once we have 7AH 21770 cells available to make a pack out of and will also have the least storage space of my vehicles other than the mountainbike(which I can wear a backpack while riding) and this Milan may be able to be set up for 400+ miles range @ 30 mph.
As for the mountainbike, I might eventually swap it out for a new steel frame with a longer wheelbase, more room for batteries, also full suspension, DOT brakes/rims/tires, and make it into a 50+ mph 72V stealth build that looks like a "normal" bicycle as much as possible within the context of these upgrades, that also runs 10kW peak. Should I do this, the mountainbike will remain something very basic maybe even downgraded to 750W while the new stealth build bike fills the role of "motorcycle".
With a fleet of these things, I can assure I always have transportation when one or two of them are down for repairs or upgrades.
