Samer
- Joined
- Jun 20, 2014
- Messages
- 110
I've fed the small block up to 5kW @ 72V with no major issues. It DOES wear the drive-train extremely fast and it was fun for a while to tear around and race everything.
I don't do any more than 3kW anymore and that only shows up on large hills...still quick, still powerful
Föppel said:looks fancy
whats the Price of this kit? And do you know the reduction ratio?
With the smallblock i would recomend to go 40amp max... but then again, its depending on your reduction ratio.
so if you want 2400w on a smallblock kit, i would go for a 72volt battery @ about 35amp, or 60Volt 40amp.
80for20 said:That's wicked!!
Do I understand correctly hat you have the Adaptto working with the L-R small block? Any issues?
notger said:80for20 said:That's wicked!!
I never had big issues, so i think the problemd discussed here were with old firmware.
I do not think that it makes any difference that i sill use the original GNG Motor, not the one From Mike.
The Kit is running pretty well on up to 2500 watts for around 1500km now.
on a bike stand, full throttle, without load the motor sounds shaky, but riding it with load on full throttle worked very!very fine until now.
You can look intor the adaptto owners od Lighning rod Thread, i posted a while ago about LR+Adaptto.
But back to you 3kw guys.
What volts and Amps do you use to get the 3kw ?
cause maybe its the fact that i (just)use 15s (60Volts) with ~30-40 Amps and get this heatproduction in my Motor.
Notger
Samer said:hey notger can you post some photos of your bike?
how hard is to setup adaptto on LR?
Föppel said:Hi Notger, thanks for writing here, nice to heare that your GnG still running well.
I had a GNG some time ago, did the whole Nr.25-Chain (? the small one with the same pitch like the 219, but tiny...) mod. Ended with a Reduction way to big, 30km/h on 88Volt, annoying noise... and to much torque
then decided to buy the whole thing new from mike.
We dont have porblems with overheat, running 45amp max, continous is more like 35amp. But we dont have temp sensors, we can only tell by hand-test... it never was that hot we couldnt touch it for long time![]()
We use the 12 fet-lyen controllers on the most Bikes. 21S-Packs with 25R, get a max of something around 3200w shown when CA is set to 3500w max. that tells me that Controller is on his max? or my CA-settings are shit?
Maybe its bove, im not much a "controller-guy"
Also my throttle (-settings...) still not ideal. like 2-3mm turning throttle gets from 1-100%. This is ok at 1000w power, but on my current setting it get uncontrollable.
dont want more power, still have to learn to handle what i have now.
i want that it acts as direct as possible, but with a wider range of the throttle... someone a idea which of the 1000 CA-Settings to change?![]()
