JQKA
I’m looking for a reliable vendor of a 250 W kit for a 700cc front wheel hub. No bells & whistles needed.
You could also get a cheap kit off of Amazon. They are a reliable vendor, in the sense that it's easy to return things. The issue with prebuilt wheels is that they use the cheapest junkiest rims on the planet. You can still get thousands of miles out of them, but spokes get loose or creaky, and the spoke holes may start to crack with a lot of miles. If you're just getting into ebiking, there's nothing wrong with going the cheap route, but if you stick with it, you'll probably upgrade things later. If it's something you're putting together for a purpose, like commuting to work or a substitute for a car, you may want to go the quality route (but you still may want to upgrade things later anyway). In either case, try to go the quality route for the battery. It can last though a few upgrades if you take care of it.Thank you. I’ll check it out.
Note that it isn't necessarily because the rim is junky that the holes crack.The issue with prebuilt wheels is that they use the cheapest junkiest rims on the planet. You can still get thousands of miles out of them, but spokes get loose or creaky, and the spoke holes may start to crack with a lot of miles.
