I did try it for a few years. In a rainy maritime environment it was ultimately way too time intensive. One ride in a good rain would require rewaxing. Rainy season meant rewaxing after every ride. As a bicycle commuter this was not sustainable. And cold weather riding (near freezing temps) caused chain skipping.No negative reports and it sounds interesting.
What type of wax did you use?I did try it for a few years. In a rainy maritime environment it was ultimately way too time intensive. One ride in a good rain would require rewaxing. Rainy season meant rewaxing after every ride. As a bicycle commuter this was not sustainable. And cold weather riding (near freezing temps) caused chain skipping.
I like Chalo's input. I tried mineral spirits to clean factory chains initially - it works much better than what I use now but is a pain to dispose of ecologically. I think gasoline falls into the same category. Therefore you end up keeping it and filtering it, which is also a pain. You also have to keep an alcohol bath ready for after too. Having a very large ultrasonic cleaner like I do helps make up for it, but not everyone can afford those.I decided to give Chalo a timeout because he's engaging in more agitation than helpfulness as of late and i'm tired of telling him to stop. This behavior is all over the site lately.
Please continue!
I would just do mine every 100 miles but since I have added a hub drive and only pedal uphill now it's probably more like 3 to 4 hundred miles now.Well, two chains done. That was pretty easy. (The ceramic pot is the exact same dark grey color as the wax....heh) First chain is just a cheap replacement on a slightly worn freewheel. The other is for the new Shimano freewheel on the shelf. Any guidelines for when to rewax a chain that's already been waxed especially a mid-drive? (I never ride wet.)
Simple, commonly available household paraffin wax, sold in convenient ~1 lb. containers (four sticks in the box):What type of wax did you use?
Yes, just washed out while riding, more from water splashed up from the tires than from rain falling directly on it.Not sure I understand why some rain would wash out the wax, I would think the opposite would be true and it would be more resilient to washout than oil.
Agreed. As Neptronix stated above, depends on the environment and user priorities.There is probably no perfect solution
The crock-pot is 120 watts on high. I melted down the two pucks (1.15 lb total) on high for about 20 minutes and they were 1/2 way liquid. I dialed back to low as some crocks exceed the boiling point (wax mfg says don't) and got busy with other projects. Checked in about 30 minutes later and all was liquid and ready to go.Do you know the wattage of your crockpot? How long does it take to melt 1 lb of solid wax?
How often do you need to re-apply Drislide?FWIW, I don't use liquid lubes or wax. I use Drislide.
Did you check wax temp with an immersion thermometer? How does a waxed chain ride on your bike? Notice any difference? I still have not waxed mine yet. Waiting for more stuff to arrive.The crock-pot is 120 watts on high. I melted down the two pucks (1.15 lb total) on high for about 20 minutes and they were 1/2 way liquid. I dialed back to low as some crocks exceed the boiling point (wax mfg says don't) and got busy with other projects. Checked in about 30 minutes later and all was liquid and ready to go.
Nope. Just let the chain sit in the wax to come up to temp for a bit to be sure the wax penetrated everywhere and help shed excess after leaving the bath. Haven't even ridden yet. Crappy weather and other priorities. My definition of success is going to be longer service intervals (~500 miles between waxes?) and longer life chain and freewheel.Did you check wax temp with an immersion thermometer? How does a waxed chain ride on your bike?
Do it anyway you want, 500 miles might be a stretch when I was on a mid -drive that needed lots of shifts it was buttery smooth with a fresh waxed chain and gradually became a little more notchier as time went onNope. Just let the chain sit in the wax to come up to temp for a bit to be sure the wax penetrated everywhere and help shed excess after leaving the bath. Haven't even ridden yet. Crappy weather and other priorities. My definition of success is going to be longer service intervals (~500 miles between waxes?) and longer life chain and freewheel.
@hillslayer@ - Heh! I went with the little crock to simplify things. My mom used to make candles. I have waaay too many memories of double boilers.![]()
Odo display on my TSDZ2 was at 1618 miles after I waxed the chain. I'll be keeping track of mileage vs how the chain performs. It's been riding fine. After 16 miles, I gave the chain a wipe with a white cloth. The black is the Tungsten Disulfide I suppose and not dirt + oil which would have been much more of a mess.Got the chain degreased and waxed (Dollar General candle + WS2) using my PID controlled coffee percolator, set to 90C then 55 C cool off before removing chain.
Took a ride this morning. Can't say I notice any difference in ride and shift quality. Big difference is how clean the chain is! Time will tell how well it stays clean.
Is all the chain needs is enough wax so after it cools the links are stiff. You guys are making up unessasary stuff. To much YouTube I guess.Thought experiment:
If you really want to keep more wax inside the chain, let the whole thing solidify before removing the chain from the wax. For this purpose it's probably best to have a shallow flexible tray the chain lays in that you can pour some wax into after the first stage of heating the chain in the melted wax for penetration,
Reinstalling it will be messy, wiht wax chunks flying during the inital ride.
I wonder if a super thin coating matters? Thinking out loud, bike chains have loose tolerances between pins and rollers so it can bend sideways to allow shifting. The gaps between pins and rollers hold wax. Extras wax in the gaps gets squished out in the first pedal stroke. What remains gets squished around in the gaps and do it's lubricating magic. Maybe having super thin coating is enough? Less waste, less mess to clean up?That looks like a super thin coating compared to what I end up with. I usually let the wax cool enough to have a skin before removing the chain. Very little drips off, but a lot comes off the first couple cranks through the drive train the next day.
