wturber said:Yep. Cool stuff and certainly a bit infectious.
This is so true ! I had never considered adding solar panels to my ebike but now it looks more and more obvious !
zro-1 said:Justin: I really love the fact that you share your encounters with people/places on your trip. The ride experience you've shared has been great, but the points where you mention meeting people along the way or people that helped you on your journey give me hope for the human race.
fechter said:Flat tires seem to be one of the biggest issues. Someplace we need a technology improvement.
Yeah. I notice that in the the Phoenix area when I ride or drive (convertible) under a freeway overpass at night. You can feel the heat radiating from the concrete that is hotter than the ambient temperature.John in CR said:Down here in the tropics I still bake sometimes in the shade, not because of ambient temps which aren't that hot, but from some things giving shade absorbing so much sun that the bottom side radiates a lot of heat.
A technology change would be nice...but there are some things to mitigate the problem now, depednign on your rim size and tire availability for it.e-beach said:Yea, like real flat proof tires. Not like the ones around now, something with real puncture proof material in the tire itself so we don't need to add anything between the tire and the tube. We are running motors after all, we can make up for the weight increase of the tire.
Yea, but the Shinko SR-741 tires start at 70mm wide. That is too wide for me and a lot of guys on mountain bikes.amberwolf said:......
A technology change would be nice...but there are some things to mitigate the problem now, depednign on your rim size and tire availability for it.......
Perhaps. In commercial/residential solar installations, leaving an air gap behind the panels is critical. Several installations have had problems because the panels were directly on top of a roof or other structure, which allowed the panels to get much hotter than they otherwise would have.wturber said:I wonder if it makes the cells themselves more prone to overheating though?
I meant SR-714. It might still be too wide, but I think there's a 2" version (I'm using the 2.5" on a 45 or 50mm rim; can't remember that width).e-beach said:Yea, but the Shinko SR-741 tires start at 70mm wide. That is too wide for me and a lot of guys on mountain bikes.
There are some kevlar-belted bicycle tires; I don't remember the names, though a poke around good bike tire sites will probably find them. They've also been discussed on ES before, IIRC. Never tried them though.I am thinking it is time for real steel belted radial mountain bike tires with heavy tread that will work as well as your Shinko tires. I think that it is weird that they are not made already. Or if not steel belted, how about double Kevlar belts or something that is also nearly puncture proof.
amberwolf said:There are some kevlar-belted bicycle tires; I don't remember the names, though a poke around good bike tire sites will probably find them. They've also been discussed on ES before, IIRC. Never tried them though.
wturber said:Don't forget to lube the threads!
I'm curious. How is the back to back scheme working out for conversation and such? The setup is counter-intuitive since we are so used to facing in the direction we are traveling for obvious reasons. But it struck me as one of the really good things about youbgur trike.
In that way all your ES fans are rooting for you and AnSo!!!!!justin_le said:Well hopefully this is the last post I make about flat tires. .......
In that way we are all rooting for changes in bicycle tire design. IMO it is really stupid that bicycle tires have to be so tender compared to all other types of wheeled transportation. I have had that same steel belted wire strand flat as you showed in the picture.....many times in my big city. Why cars and motorcycles can roll over them and not get flats but bicycles are almost required to go flat from them probably means that manufactures have a high rate of return from the puncture resistant fables they sell to us 365 bike riders. It is time for a change.justin_le said:......In any case,flats.., just an occasional fact of life when doing long distances by bicycle.
e-beach said:In that way we are all rooting for changes in bicycle tire design. IMO it is really stupid that bicycle tires have to be so tender compared to all other types of wheeled transportation. I have had that same steel belted wire strand flat as you showed in the picture.....many times in my big city. Why cars and motorcycles can roll over them and not get flats but bicycles are almost required to go flat from them probably means that manufactures have a high rate of return from the puncture resistant fables they sell to us 365 bike riders. It is time for a change.
justin_le said:The one thing that hasn't worked as well as I was expecting is communications. I thought with our heads close together like this that we'd be able to talk while riding without yelling, but that's only the case if we have a nice tailwind and no traffic. At one point we started using a walkie talkie phone app and using phone headsets to chat. It worked decently well but becomes a bit of a wire jumble trying to have the microphone pickups from the earpiece to fit at the right location.
wturber said:Bummer. So it sounds like the main issue is wind noise and or traffic noise? I can imagine that for wind noise that "cat ears" might work for the rider on the pedals, but would they work in reverse for the rower?
https://www.cat-ears.com/cycling
