Christenson58
Hello All, I have a friend that asked me to help him with his Rad Rover. Does anyone have any leads on where I can get info on this motor? It's off a 2-3 year old Rad City 5 Plus. It's got a bad Hall Sensor and this motor is not like the older motors. Wiring on this one comes out the brake Side instead of Drive side, so doesn't come apart like the older ones. Trying to take it further apart at this point and it sounds like the large metal plate is hitting ring gear, but I think it will actually clear it. It won't tap/hammer out like the older motors and I'm thinking I may need to use a 3-prong puller to push it through, as the magnetic hub maybe pressed in under ring gear... but I don't know for sure.
The motor runs good when I reset the battery and punch throttle with wheel off the ground, but will flash a code 24 and stop working after first stop.
So, I want to get it apart without damaging anything to try and replace hall sensor, but for not knowing the setup behind this plate and using a puller now on the Drive side, would be me driving blind at this point. Problem is I can't find anything on it on the Web. Sorry for the crappy pictures, I should have taken better ones, but I thought I was going to just be replacing the motor, so I put it back together and back on the bike to make it still ride-able. TIA
