No help here
Forums
Only work if questions get answered, Mine must be too insignificant to be acknowledged. So
S
1) No one owes you an answer
2) Even if people can help, this is a pretty slow traffic site -- it might take days before the right person sees your post to answer it
3) You posted like somebody having a stroke.
If you want to evoke more helpful response, post better questions. Clearly explain what your goals are. Cover what you have tried. Show what research you've done prior to lazily firing off a question and putting the work on other's. Take some (good) pictures so people can visualize and asses better.
This place is filled with technical, smart, and helpful people. Be better.
Your question wasn’t insignificant, it just didn’t provide any information whatsoever for anybody to answer.
Try this:
We have an old Chinese e-bike and are replacing the controller with a (type the make and model of the new controller and post a decent photo showing the controller and all of the wiring).
And here is a photo of the throttle (post a decent photo of the throttle and its wiring).
Unfortunately we don’t know where to plug the throttle into the controller.
Can anybody help please.
Forums
S
Someone responded and requested more info. You never responded on the forum. Was his request for more info too insignificant?
I looked up a few of mikeorrison's posts, and there seems to be a severe communication problem. Mike, are you posting from a different language using a translator, or are you using a transcribing device?
Fwiw i answered an oblique post with an equally oblique response. - perhaps not my best moment, but after typing out a polite paragraph asking wtf? - and retyping as to not sound condescending, i ended up thinking WTF! - "Tuesday"
Hi. I looked over some of your earlier posts.
(A) society is designed by the average for the average. I don't fit some ways, but I can't change all of them. With time, I have worked out some accommodations that let me get some of what I want.
Unless you physically can't, please get a keyboard to use rather than the dictation on your phone. Reliable entry could remove some of the problem for your side. I don't like the dictation on my phone either. The same if you can get a computer instead of using the phone?
Although it might be a chore, perhaps post after a while, so it's not urgent and you've had time to compose your question. I do this a lot because it helps me. I almost always phrase better if I leave a bit of time.
You know we can't help without lots of information - can you work that in and always expect to take some pictures, expect to name manufacturers and provide links (if you can find them), work up descriptions of the issue as if you were speaking to someone that knows less than you do? That last is a good measure of how much to explain. We'll probably need it, as we can't see/know what you already do.
I work in software, and we must explain EVERYTHING IN GREAT DETAIL to the computer all the time. Otherwise it doesn't know. So I'm somewhat used to it.
A lot of this is just how it really is for all of us.
If I wasn't so stressed out from doing everything right and thing's not working the way they're supposed to. Maybe I'd prove read free some of these little more carefully. Excuse me, thanks for showing me enlightening me on how to post a post or question, but it doesn't go near what I'm looking for as far as information is concerned, so thank you but. I don't have ready to get some wire. S apparently, I always get once a purple with a loop running in it. So it should be on, shouldn't it plug the battery and rate? Well, the one did that. And then the vote went from 5 to 4 when I plugged the throttle t le line in. ? I don't know.
I'm posting from severe stress land because things don't do with their supposed to. My anchorish wire seems to always be purple.In a loopand shouldn't that turn on soon as I plug the battery in the box?Be ready to go These S8886 controllers are all different. I once got 7 wires once we got 5 wire But those you don't have the T HR OTT. L. E! line even hooked up It's like you're keeping guessing until I get it right cause no one makes sense to me or makes sense to me but it doesn't work when I do it to apparently, I don't know how to make sense to this is about a train electrician. Seems to me. It shouldn't be a difficult. I guess you when you order the things together. They're supposed to be compatible, but they send you the ones that aren't with no diagrams for wiring. Hear anything ever when can we ever get wiring? Diagrams with allow me order stuff and you haven't sent here. Why can't I find the store to buy actual control box at a person why? There's no where to buy extra rocks in person then it wouldn't window where to buy one in person.Let me know excuse me for stressing out.But this is ridiculous but I frocking can't get
I probably couldn't find out how to read my responses on your website. Because I'm stupid and technically challenged navigate to Website.
Well, if I ever come across that response, I'll try to get back. And give a more information, but I don't know what I'm looking at Apprecia.
Te it what you guys are trying to do. But if I can't you know find your responses to my questions? Which I can hardly even get for you. Post it that makes sense. Cause I'm just out of shit. I've done it a couple of times I've gotten easy bites to go but should we argue that they aren't done what they're supposed to do? Show me I have a single rendition wire. I don't have one I got a purple wire loop with a red 1. That apparently should be the condition wire as far as I can tell. And would that be turning the box on when I put the battery in submit? Yes, 88H6 controllers. Once you have 5 wires on the S6 wires. Once I said a wire, someone in your order, once they're supposed to be compatible with your control box and they send you the wrong to contact echo trick and anyone want to be assholes. And that's what I'm trying to sell you. Shit, and I'm going So I apologize, cause I'm stupid.I'll try to be more calm and send questions that makes sense.I guess.
I'm gonna take me two days just to type it all outteso
Grin has a real store, don't they? And comprehensive documentation including wiring diagrams for every version of every component. I think you are just suffering some self made issues here from buying cheap, undocumented, generic kit from reselling drop shippers who know nothing about their product. I've had AliExpress sellers just slap 30A stickers on controllers, then when I get them up and running the settings max out at 15A, for example. Don't buy from a seller that can't give you a wiring diagram.
Anyway, wire color is largely meaningless. Tough to help you without comprehensive pictures of what components you are trying to connect and what all their connectors are too. Just asking what an A&E connector is - difficult to answer. Posting a good picture of the controller label and every connector and pictures of what you are trying to attach it to? Probably not too difficult to figure it out from all the other connectors there - it's rare for cheap generic stuff to come up with something new. Common to not support something to save money, yes, but not common to have some new, unknown connector.
I'll try to do better. There would be nicer if they would send me some wire diagrams with these things, and it would also be helpful if they sent me the throttled. And then with the control box that work together. We'll sleep on sometime. It's not alwand when I try to contact these companies. I can't even find a company named on somebody's things it doesn't help. One if my educational wire is never a single word wire. Usually a purple wire in a loop should not be turned on when I plugged the battery in well. Just do that and if it missed. Do I get the display LED hookedude? I'm calling controller. Others called display. That's a trolbox. It's like it's like it's a cholera. I guess I'll just have to waste more money.Orders some more control boxes that have to paddle.The Ronald's place and hope there's the right ones to work together.So that's your only time I've had success.
No let me prove read this first before I send it so give me couple hourI'll try to do better. There would be nicer if they would send me some wire diagrams with back by these things, and it would also be helpful if they sent me the actual thing that's throttled. And then with the control box that work together. We'll sleep on sometime. It's not alwand when I try to contact these companies. I can't even find a company named on somebody's things it doesn't help. One if my educational wire is never a single word wire. Usually a purple wire in a loop should not be turned on when I plugged the battery in well. Just do that and if it missed. Do I get the display LED hookedude? I'm calling controller. Others called display. That's a trolbox. It's like it's like it's a cholera. I guess I'll just have to waste more money. Orders some more control boxes that have to paddle. The Ronald's place and hope there's the right ones to work together. So that's your only time I've had success.
No, let me prove read thispersed before I send it, so give me a couple hours.sssetIItteeoedddeers
How long are you going to keep using the same old excuse? Just don’t post when you’re stressed.
So my control box has a purple wire and a red wire in a loop. .When I hook it up to the battery.That's Turns control box? i think.Or do I have to run a hot wire or somehow to the loop
The red wire from the control box comes out at battery voltage.Then loops it to the purple wire.Which I assume is the ignition wire Then why can't I turn my l e d display on
How about buying components that have instruction manuals that explain these things?
I hope that was clear enough.No confusion.I hope
TAKE A PICTURE. POST THE PICTURE HERE. I CAN NOT COMPREHEND WHAT A LOOPS IS?
Look up. See little icon that says Insert Image (Ctrl+P) Please let me know if you need help to get pictures from your camera / phone to the internet.
When I read "loops it to the purple wire" This is what I see in my mind.
We want to help..
Can you name or provide a picture or a link to your controller (the silver box)?
Can you do the same for the display (led?)?
what size battery (volts) ? and what size motor (watts)? Hub or mid drive?
Most controllers will only work with one or two display options. So general advise is to buy as a pair.
Perhaps check for diagrams and instructions prior to buying selecting only sellers who provide information as candidates to buy from?
You mention an 'educational wire'???
Is your controller a 'self learning' type? Have you got as far as executing the learning?
I dont understand who Ronald is or why
