chrisvoi
Ok here's where it started ,, I was given a 1000w voilamart wheel and other bits to get me started, since then I've sorted the battery and other bits and everything for the most part has me perfect, the wheel came with couple spokes missing buckled rough and dusty , once I'd fixed all the issues the wheel runs great no issues ... BUT every couple of rides I would have to tighten up the M14 axel bolts to stop a loose wobble the wheel had wasn't really a problem but ovb wasn't supposed to be like this , I then replaced both sealed bearings from inside the hub because I thought maybe this could be the issue, they where sweet ,, but replaced anyway, since then I've just had to tighten them up hoping to grab some nylon type locking nuts next time the wheel had to come off ..... SO recently I've gone to tighten the nut in question and it literally turns on the axel doesn't tighten up anymore , although it isn't loose and cannot be turned by hand how am I or could I remove this but to inspect whether I've threaded the nut or the axel thread one being easy fix another being a complete pain, btw all washers are in good placement and tourqe arm installed ect and I presume I've overtightened the nut as I have been using a crossbar style thing used for car wheels ! Does the job any help or suggestions would be greatly appreciated thanx .
