Problem cut off motor
jtderik
Hi after some time cycling the motor cuts off.
Display stays on but power watt goes to zero wenn i keep cycling motor does not restart. When i stop cycling (hold pedals) and then start cycling goes up to max power 800w and stops then again. And then i need to do the above again. Voltage keeps up.
Any idea what causes the problem? (wenn i lower max power it takes longer before this issue happen)
See below spec and foto controller
Risunmotor 48v 350w brushless gearless motor
48v 20ah battery
48v 43ah boot battery
