edelweiss
2016 Outrider Horizon Trike all terrain leg pedal, + electric assist (throttle). Serial #: 1120. Purchased in 2021 with only 50 miles. .Current mileage is approximately 1000. Utilizes proven Outrider carbon belt-driven electric drivetrain technology, paired with state of the art planetary gearbox for improved performance, durability and capability. New in 2022 installed Outrider 2000 Watt Brushless Permanent Magnet Mid-Drive Motor, with reverse.93% Efficient, 25 mph max. Battery Chemistry: Lithium, 18650 with automatic BMS. 2016 original 1kW battery. New in 2021 1.51 kWh onboard battery. New in 2022 1.51 kWh onboard battery. New in 2022 On-board charging with built-in high speed 1000W charger (~1 mile range per minute of charge), for maximum durability. 11-speed rear internally geared Shimano Alfine hub with Di2 electronic shifting system. Independent A-Arm Front Front Geometry with automotive-style front swaybar for excellent cornering stability. Single-Pivot Rear Geometry. Suntour 200x57 air shocks with adjustable rebound for a superior ride, handle dirt and gravel roads with ease and comfort, Dual Magura Hydraulic 180 mm Front Disc Brakes. Rear cargo rack. Ortlieb bags custom mount. Custom mounting labor for Emotion Apex K005 Wheelchair (easily removed). Parking brake single-sided. Headlight LED 2" 900 lumen. Rear running lights. 4' LED visibility whip - color: white. Toe-strap compatible flat pedals . Price, $8,700.
The original base price $10,000 plus $2,000 for 2000 watt motor , $1,200 extra each for second and third battery, $400 cargo rack $150 reverse, $1,100 Shimano Di 11 electric shifting, $75 4' electric wand, $590 lighting package, $270 body point strap package. Trike is in Maine
