It looks like it's set up for a low voltage cutoff of 37v, so 26v would be below the cutoff. Maybe try lowering the cell count in the setup and see if it runs.
It is if its making that much heat just turning the rotor and prop in the air.That's probably the voltage regulator. 32C isn't too bad.
A relative built one of those from scratch.Test run at 24 volts. This thing will barely take 2 people but gliding through glass smooth water is so therapeutic.
