MangDav
- Joined
- Mar 31, 2022
- Messages
- 29
I was given a battery that I was told sat for about 4 months without charge, it's a 13s 54v nominal pack. It did not want to take any charge and voltage at the discharge side was 39.8v. I opened it up and started measuring the voltages at the balancing connector, it went;
3.64
7.44
11.24
15.01
18.70
22.50
21.00
24.60
aftet that I stopped after seeing the 21.00. All the ones before that one are about .17v of each other. I thought that 21.00 series need to be charged up so I hooked up my DC power supply and no current is being pulled, it just sits at the voltage that I set it to however if I plug it to any series before the 21.00 it takes current but any series after 21.00 it does not. This is a first for me. I did trace that 21.00 balancing wire and confirmed that it did not come loose. Also when I probe the 21.00 series or any after it with my multimeter, I can watch the voltage slowly drop the longer I hold probes to it, the series before that one don't do that. Are these just bad cells and I should drop the battery off at battery reycling?
3.64
7.44
11.24
15.01
18.70
22.50
21.00
24.60
