Bang up job on google's part.
Here's the response from Deepseek R1 ( either the first or second best open source model you can run )
To program your Bafang controller for more speed, follow these steps
cautiously. Modifying speed settings may void warranties, violate local e-bike laws, and strain your motor/battery. Proceed at your own risk.
Tools Needed
- USB Programming Cable:
- Software:
- Bafang Configuration Tool (Windows) or BESST Tool (requires dealer login).
- Download: SDZ Bafang Config Tool (community version).
Step-by-Step Guide
- Connect Hardware:
- Turn off your bike.
- Plug the USB cable into the motor's display port (near handlebars) and your computer.
- Install/Open Software:
- Install the Bafang Config Tool.
- Run the software and select your motor model (e.g., BBS02/BBSHD).
- Read Current Settings:
- Click "Read from device" to load your current configuration.
- Adjust Speed Settings:
- Speed Limit (km/h): Increase from default (e.g., 25 km/h → 45 km/h).
- Wheel Diameter: Set accurately (e.g., 26", 700C). Avoid under-reporting to "trick" the system.
- Current Limits:
- Increase Basic Current (e.g., 18A → 25A) for more torque.
- Caution: Exceeding 30A on BBS02/BBSHD risks overheating.
- Write Settings to Controller:
- Click "Write to device" to save changes.
- Restart the bike and test.
Key Settings for Speed
| Parameter | Default Value | Safe Max | Risk |
| Speed Limit | 25 km/h (15 mph) | 45–50 km/h | Motor overheat, legal issues |
| Basic Current | 15–18A | 25A (BBSHD: 30A) | Battery/controller failure |
| Keep Current % | 50–70% | 80–90% | Reduced battery life |
| Wheel Diameter | Accurate size | — | Set correctly for speed accuracy |
Important Notes
- Legal Limits: Most regions cap e-bikes at 25 km/h (15.5 mph). Exceeding this may classify it as a moped/motorcycle.
- Safety Risks:
- Overheating motor windings or MOSFETs.
- Premature battery drain or failure.
- Display Tweaks: Some Bafang displays (e.g., DPC-18) allow temporary speed limit overrides via hidden menus (check your manual).
- Cadence Matters: Higher speeds require fast pedaling to maintain motor assistance.
Alternative Solutions
- Voltage Upgrade: Swap to a higher-voltage battery (e.g., 52V instead of 48V) for a ~10% speed boost.
- Gearing Changes: Install a larger front chainring (e.g., 46T–52T) for higher top speed.
Disclaimer: Modifications may damage components or violate regulations. Consult local laws and a professional if unsure.
For advanced tuning, see the
Endless Sphere Bafang Forum.
... they must have trained this on our website
I think this answer is pretty good and i like that it links to ES, despite misnaming us.
Here's the same question on Qwen3-235B-A22B-2507 ( half size version of the 1st or second best open source model right now )
Programming Your Bafang Controller for More Speed
There are several methods to adjust your Bafang controller for higher speed, but it's important to understand the legal and safety implications first.
Methods to Increase Speed
Using Display Menu Settings
Some Bafang controllers allow speed adjustments through the display menu. You can set the maximum speed to 50km/h and adjust the speed percentage to achieve your desired maximum assist speed. For some models, you can simply stop and press specific buttons on the handlebar display unit to set speed limits.
Using Programming Cable and Software
For more precise control, you'll need:
- A programming cable with USB connector on one end and green Higo connector
- Bafang Config Tool software
The programming process involves:
- Connecting to your drive system
- Finding your COM port
- Opening the Bafang Config Tool
- Adjusting specific parameters
When using the config tool, you can modify settings such as current limits and assist levels (e.g., Level 0: 0, Level 1: 10, Level 2: higher values).
Important Considerations
- Legal Limits: Many regions have legal speed limits for e-bikes (commonly 32km/h or 20mph). Exceeding these may make your e-bike illegal for road use.
- Risks Involved: There are significant risks when modifying your controller, including potential damage to components, reduced safety, and voided warranties.
- Model Specific: The exact process varies depending on your specific Bafang model (BBS01, BBS02, M620, etc.).
Before proceeding, I recommend:
- Identifying your exact Bafang controller model
- Researching the legal speed limits in your area
- Understanding the risks of modifying your e-bike's programming
- Considering whether the potential benefits outweigh the risks and possible warranty voidance
If you decide to proceed, the Bafang central motor programming guide provides detailed instructions on configuring your motor while protecting it from possible breakdowns.
Again the first cited source is endless sphere.
Interesting because i've been kicking alibaba off this website whenever i see them because of abusive scraping practices. I guess they picked up just enough data!
This answer is less impressive but this AI model has 1/3rd the data packed into it as deepseek.
Asking it a more difficult question:
I didn't expect this smaller AI model to do anything but hallucinate things but it did okayish.
How'd deepseek do?
Luke "Liveforphysics" Workman is a legendary figure in the electric vehicle (EV) community, particularly on the Endless Sphere forum. Here's a comprehensive overview of his contributions, identity, and impact based on available sources:
1. Identity and Persona
- Username Origin: His handle "Liveforphysics" reflects his obsessive passion for applied physics and extreme engineering, particularly in high-performance EVs29.
- Real Name: Luke Workman, a self-taught engineer known for hands-on experimentation (e.g., surgically implanting a rare-earth magnet in his finger to "feel" electromagnetic fields)211.
- Personality: Described as a "modern-day Nicola Tesla" – brilliant, unconventional, and relentlessly innovative, with a focus on solving real-world problems211.
2. Technical Contributions on Endless Sphere
- Forum Activity: A prolific contributor to Endless Sphere, especially in high-power ebike/motorcycle builds and battery technology threads2911.
- Deathbike Saga: Documented his creation of the "Deathbike," a DIY electric motorcycle that reached 80+ mph and famously outpaced a Tesla Model S P85 in a drag race (110+ mph)911.
- Controller/Motor Expertise: Shared advanced controller programming techniques (e.g., tweaking Bafang Ultra Max controllers for safety at high power) and advocated for robust motor systems like the Agni axial flux motor29.
3. Professional Work & Innovations
- Zero Motorcycles (2009–?): As a battery engineer, he revolutionized their packs, tripling range in his first year and quadrupling it later. He also integrated Agni motors into prototypes911.
- Luna Cycle Collaboration: Consulted on potted battery packs (Luna Fusion), making them waterproof/shockproof. Pioneered alternatives to spot-welding for stronger pack construction2.
- Battery Recycling Startup: Co-founded a company focused on ethical lithium battery recycling, addressing a critical gap in the EV ecosystem4.
4. Signature Projects and Philosophies
- Performance as Spectacle: Believed high-speed EVs could inspire adoption by "being a spectacle" – e.g., his 80 mph ebike raced against gas bikes at Willow Springs9.
- Extreme DIY Culture: Built Franken-bikes with salvaged parts (e.g., a Zero DSR with custom charging ports and disabled safety interlocks)2.
- Open Knowledge Sharing: Advocated for open-source principles, echoing Endless Sphere's ethos. His posts demystified high-amperage systems and thermal management211.
5. Legacy and Industry Impact
- Influence on EV Culture: Inspired a generation of builders, including professionals like Stéphane Melançon (battery expert) who credits Luke for his career path11.
- Speed Records: Held unofficial ebike speed records; his Deathbike remains a benchmark for DIY performance911.
- Environmental Mission: Viewed EVs as tools to "wean society off fossil fuels," driving his work in batteries and recycling24.
6. Controversies and Risks
- Safety Boundaries: Known for disabling safety features on prototypes (e.g., throttle interlocks), leading to crashes and stripped gears2.
- Skepticism Toward Projects: His battery recycling venture faced initial doubts about feasibility, though supporters emphasized his track record4.
For deeper technical discussions or build logs, explore his Endless Sphere threads (
forum link)39. His work exemplifies how DIY ingenuity can propel industry-wide advances in sustainable transportation
Damn this is actually quite good, i'm not sure about the rare earth magnet in finger part though.
Deepseek R1 is really great at synthesizing a response from a bunch of web links in a way that's coherent, and all these numbers in the response are weblink references. I like that it cites it's sources.
What about generating a short summary?
..okay a little long, but the question was vague. Imagine this as a thread summary. Would you say the AI did a good job?
I read a gazillion liveforphysics posts back in the day and i'd say, this is generally on point and pretty good.
The only question is how well it would handle a single thread. That's the part we don't know.
Luckily, some Xenforo developer is currently writing the software that could do the thread summary part and we don't have to engineer this to find out, we just gotta buy their plugin to run the experiment.
