markz
100 TW
I have had this idea in my mind for some time, ever since I was trying to figure out proper ways to connect batteries securely.
Most likely after I read the magnet, no tab-weld build someone did.
I believe this technique will reduce the heat that the battery recieves. I might try some thicker strips around the hole to eat up some of the heat, but leaving the hole clear for solder to make contact with battery end.
Here is the Rosin I bought, I am not sure if this is the right stuff.
I have to head on out of my cacoon, and hit up my electronics store, for a big roll (0.5lbs) of 63/47 solder. Been trying out a bunch of tests lately. Is that the right Rosin to use for soldering?
