Indeed. I saddled a one-legged trike for almost two decades. Actually, that's not entirely accurate - RH wheel motorized, LH wheel pedal, so technically it was independent 2WD.I have seen the product page on some of the Grin kits state you can have a functional trike with only one side wheel or the other powered too, though.
How easy is it to transfer power on a bike like this? I was thinking about two chains for each wheel separately.
Yes, as long as there is enough tension to keep it on the sprockets. Otherwise, sidewall friction of the chain and teeth could cause it to ride up on the teeth and come off the sprocket. That's a problem I encountered on the Raine Trike I built for my brother.Can the bike chain work at an angle?
Sure. Delta Tripper above was motor power on the right, pedal on the left. Later the same rear end was used to build SB Cruiser which still only has pedal on the left, but has motors on both sides. (thread links in the post above).I have seen the product page on some of the Grin kits state you can have a functional trike with only one side wheel or the other powered too, though.
I couldn't find an answer on Polish websites, so I'm asking you.ale prawdopodobnie ma przeguby krzyżakowe z centralnego mechanizmu różnicowego, który jest napędzany łańcuchem pedałów, dzięki czemu oba tylne koła są już napędzane pedałami."
That all said--based on my experiences with what was probably a similar length and seat height and track width (see the), I highly recommend keeping it under 10-15mph at most.
In the instance of the one you picture, it's image name says it's a leaning trike, so one coudl assume that it tilts and rides more like a regular bicycle.Thanks for the links. I've read these and many other posts about tricycles. They suggest that a stable vehicle should be long, wide, and have a low center of gravity. I haven't found any information about a completely narrow tricycle, like the one in the photo below.
Is it also tippable, or does it handle more like a two-wheeled bicycle?
If the current setup has bike chain drivetrain and gearing, maybe a mid drive would work better.I couldn't find an answer on Polish websites, so I'm asking you.
Regarding power, Polish regulations limit the engine's power to 250W continuous. The engine must be started using the pedals and turned off after reaching a speed of 25 km/h (15 mph).
I also think the photo shows a differential with a shaft and spiders, and if I don't find a lighter and simpler solution, I'll go that route.
Does anyone have experience with this type of differential mechanism?
I'm guessing you've not sampled a tad w/4" fatties (@20psi) and 2/3 gross planted on the steer axle. Doesn't get much worse than that.A trike with a single wheel in the back is going to be enormously easier to drive.. and also enormously better in cornering..
Here's a video of one in motion:Man i looked at many pictures of that bike and do not see a pivoting or suspension mechanism in the rear..
At $5.5k entry price it would be cheap for such a thing.
Let me know if you got pics or details. that sounds like a cool bike.
I think the easiest is a front hub motor. I have one wheel turning in the rear, the other is free. I don't want a differential because that's just more moving parts to break. I like simplicity. Off road I pedal, than I have front and rear drive. I Cruze 10 to 15 mph comfortably. Over that I don't feel safe as I know I'm not as agile as a 2 wheeler. Turns I slow down, but not that much. Once you get used to the feel, turns get fun. You can almost feel the line you don't want to cross, where one wheel in the rear almost comes off the ground. cheersHow easy is it to transfer power on a bike like this? I was thinking about two chains for each wheel separately.Can the bike chain work at an angle?
@ the 1:00 mark it's doing a gentle turn and looks ready to flip. I'd suggest a sideways sliding seat so you can change the c-o-g. I do it on my baby the rideon mower all the time on slopes, just swing my butt off the seat like I was taking a corner on the motorcycle and the deck sits flat on the grass.Here's a video of one in motion:
