Stealth bomber replica 8000w electric fault
Kennyken5072
Peterborough
Hi all I have posted about this previously.
I've had new converter sent from the factory with a newer version as well they instructed try new version first which did also the new original type as well and nothing still the same.
Something else I've noticed when you pull brake levers it cuts the motor off since this lighting and indicator also brake light fault am starting to think controller fault unless there's a broken wire from converter to control module but this cut off from the brake is worrying as well am going to work my way through the wires and test if all good has to be controller.
Any advice or anything I've not thought
Help be very much appreciated
Thanks Steve
