Confession, i haven't caught up with controllers for 10 years.
I still use old infineon 9-18FET models because they are simple, well documented, cheap, had good FETs, and very reliable.
I also have phaserunners but they are too expensive for builds with cost constraints.
I would like to move on to programmable sinewave or FOC controllers, but there seems to be no clear winner as to has the best one.
I've browsed threads for a while and the consensus seems to be:
KT - has problems with drag on direct drives when throttle not engaged, otherwise seems good?
Sabvoton - seems to be good?
Kelly - continues to have below average reliability and also full of quirks for many, same as the 2010's
Powervelocity - website broken and not responding to emails.
Cutler MAC AKA MAC motor tech ( supposedly still sells infineon clones ) - Not responding to contact form on website.
Nucular - Can't buy the 6F, no cost mentioned, imagining not cheap
Fly by night Chinese brands - Not interested because you won't get support down the line.
Given that i want:
+ Relatively cheap for cost constrained builds
+ Supports phase advance/field weakening of some sort
+ Supports a 3 or 2 speed switch
+ Supports a CA or has a nice screen with amps/volts/watts display
+ Halfway decent FETS ie 3077 or 4110 grade
What would fit the bill best?
Given that i want:
