Peter Sternersson
Obviously I need to buy a converter, in fact I ordered one at the same time I ordered the controller.
But why even use a decade old outdated connector to begin with? None of my laptops since at least 6 years back has been fitted with one. Ah well, old dogs are hard to train I guess...
Anyhow, my friend came over with his computer and hooked me up...
Altering the throttle sensitivety (throttle up/down ramp) didn´t do much good, couldn´t feel any difference at all actually.
We ended up limiting the current to about 50% (6kW), this at least made the take off possible without hanging over the front tire.
However, the plan of beeing able to run the bike legally here in Sweden (250W, 25km/h only with pedal assist) seems to go down the drain if I cant turn of this quick launch setting in the controller.
The plan was to install a thun or pas connected to the CA, and set the proper limits in there. This wont do much good if the controller pushes 20 times the legal power, regardless of what the CA says
I had a maximum amp reading in the CA of a respectable 146A at 73V = 10,6kW.
I´m guessing this is the controllers max, pretty good for a 10kW rated controller, as I had read that Kelly greatly exaggerates their numbers...
