Hello im stuck with this controller, I did some modifikation changed battery wires to 6mm² copperwires, and phase to same with better contacts.
I did solder on copper tread 2,5mm² along plus and minus and along mosfet to phase line.
I tested on a motor and I got a reaktion on trottle for a second and The motor spinned to cut of after 1sek for about 5times then No more response at all tried another motor no response. Everything else works lights etc. I got 0,8v to 4.3v on trottle signal wire and 5v on trottle plus. I got 5v on each hall sensor for each phase. On plus hallsensor i got some lower value around 3.6V.
Before my solder i got 9.3 kohm resistens between phase and ground and now its around 3.5kohm.
Is this the problem? I guess there is some over current protection that hits? I did notice that there's a thinner line by default last sektion on minus i did go all the way.
If you would help me i would be very happy
