knightmb
I bought this one:
http://www.poweridestore.com/Hub-Motor-Torque-Arm
Pros:
Cons:
Conclusion:
I was very impressed with this. It is very strong and easy to install. In my experience, the front fork always fails on the side in my pictures due to rotational forces on that side wanting to "spin out" of the fork where as on the other side it's trying to "spin in" to the fork. If you are going to use anything above 36 volts on a non-steel front fork, I recommend getting one of these. It's very strong and with my test at 72 volts, didn't even move a little in my test of just pealing out from a dead stop over and over with all of my 175 lbs of weight on it (plus battery packs, etc). I think this helps those that want a front hub motor out greatly in preventing a fork failure at least up to 72 volts on a 406 motor. Not sure what would happen if you had a more torque monster in the front. A very easy and cheap way to power up the front hub for some torque and speed.
Pros:
- Cheap compared to having a local shop fab one for me
- Straight forward steel, very strong.
- Has a side attachment plate (removed in my pictures) to run power cable should you put it on the same side as where the power cords come out from the motor
- Designed for this kind of thing, fit without any issues on even my large shock forks
Cons:
- Screw to bind it to fork not big enough for mine. Had to make a trip to hardware store for a longer screw and bolt.
- Locking washers would be nice, again, cheap hardware store trip for this one.
- Heavy
Conclusion:
