igashosparks
- Joined
- Jan 6, 2023
- Messages
- 25
Hi All,
I'm trying to open my 8000W (likely clone) QSmotor to replace a failed hall sensor. I got it halfway opened, but can't get the remaining outside panel off to expose the Hall Sensors.
There is a BMX style freewheel sprocket attached to the threaded axle (going through the motor). I can't tell if I need to remove the freewheel first, or if the axle will simply pull through the freewheel if I was able to overcome the magnetic pull. I've done some research, and see that some need to use a gear puller link this:
Or do I need to remove the freewheel first and then use a gear puller to overcome the magnetic force.. I was able to use the the cement floor to press through to get the other side off.. (It was pretty challenging)
Any thoughts are appreciated!
